Old 11-11-2018, 03:54 PM   #11
Ed Wright
Ed Wright's Avatar
Default Re: 2 step pressure switch question
When I went to Super Stock, with a trans brake, mine is enabled with my Trans Brake button. Brakes at the finish line has no effect.
When I was foot braking, I had a spring loaded-to-off toggle switch on my shifter, that was "On" only when the lever was in low gear. I used brake light switch on the pedal, up under the dash on these F body cars, to energize the 2 step. Very trouble free deal.
Ed Wright 4156 SS/JA
Old 11-12-2018, 03:10 PM   #12
Jeff Teuton
Liked 325 Times in 50 Posts
When I had a two step in Stock, we used a MSD Window Switch for activation and at the end, there was no function. You only have to put the brakes on once at the top end and have the two step come on to figure something out.
Jeff Teuton 4022 STK
Old 11-12-2018, 03:42 PM   #13
Chad Rhodes
Harrington button in place of brake light switch. Adjust it far enough that you have to be on the brakes really hard to trigger it
Chad Rhodes 2113 I/SA
Old 11-12-2018, 09:12 PM   #14
Ed Wright
Ed Wright's Avatar
The factory brake light switch on F body GM cars like mine are also adjustable, a tad over an inch of adjustability.
Old 11-15-2018, 12:54 PM   #15
ron mattson
Liked 69 Times in 32 Posts
Whitman controls makes good adjustable
switches!
Ron Mattson 5015 STK
ron mattson is offline   Reply With Quote
Old 12-10-2018, 10:44 AM   #16
RobbieRacer
RobbieRacer's Avatar
Liked 118 Times in 41 Posts
Would anyone be willing to tell me exactly which in line brake switch they use? There are so many options I am completely confused. I need to get one ordered ASAP. PM me if you don't want the world to know.
U/SA
79 Mustang
Old 12-10-2018, 11:37 AM   #17
Alan Nyhus
Liked 799 Times in 236 Posts
Robbie, check your PM's. -Al
"That'll never work....."
Old 12-10-2018, 02:13 PM   #18
RobbieRacer
Thank you for all your help Alan, Got my switch ordered.
U/SA
79 Mustang
Old 12-10-2018, 05:11 PM   #19
Coleydog
Liked 53 Times in 38 Posts
I have a few questions, do you feel the two step helps 1- your ETs 2- your relaction times 3- your launch or just its less trouble maintaining a certain launch rpm? Is it more critical with a short stroke engine than a bigger one.
Mike
Old 12-10-2018, 09:41 PM   #20
Eman
Liked 133 Times in 76 Posts
2 and 3 for me. Only used on the stock stroke 355SBC I run so I can't comment on other engines. I feel it makes RT's better and more consistent because of set RPM and one less thing to think about.
https://www.jegs.com/i/JEGS/555/63070/10002/-1
This basically the switch I use, mine is a Borg Warner from local parts store.
