Old 11-27-2018, 03:44 PM   #1
Lyn Smith
Liked 986 Times in 198 Posts
Red face 305 engine block question
Planning the build for my next 265 Stocker motor.Will using a 305 block with the spacer bearings like I did for the first one.Are there any 305 blocks(cant afford a Bow tie) that are better to use than others? I will be boring it .060 (3.790).Thanks for the info.
Old 11-27-2018, 05:36 PM   #2
Tim H
Tim H's Avatar
Liked 482 Times in 159 Posts
Default Re: 305 engine block question
http://classracer.com/classforum/sho...t=canadian+305
Old 11-27-2018, 05:48 PM   #3
SSDiv6
Liked 1,586 Times in 583 Posts
This Ebay seller has a few of these blocks both 0.040" and 0.060" O.S. for sale.
https://www.ebay.com/itm/Small-Block...-/172866626342
Old 11-27-2018, 09:10 PM   #4
Lyn Smith
Why does that guy have so many 305 blocks with no main caps??Another question is it a must to pour a 305 block?
Old 11-27-2018, 10:29 PM   #5
carl hinkson
Liked 18 Times in 10 Posts
.060 Over blocks you my want to sonic test before you buy it.
carl hinkson is offline   Reply With Quote
Old 11-27-2018, 11:19 PM   #6
Dean Feiock
Dean Feiock's Avatar
Liked 49 Times in 15 Posts
You may want to check with tech on the legality of a 4 bolt block. Back when my engines were built, I was told by Div 5 that a 4 bolt was not legal, only 2 bolt. But, that was a long time ago and things have certainly changed.
The eBay add states the block is bored and finshed honed. Um, how is that possible without caps on it. While I'm no machinist, I don't think I've ever heard of a block being bored and honed without caps on it.
Buying that eBay block, then adding caps to it, and then working out the bore will not be "cost effective".
If your going to spend that kind of money, I would recommend you sleeve a larger bore block or go aftermarket. I have a 350 sleeved and a 307 sleeved. The 307 block I used was an early model, cast in a 350 mold. It had very thick walls to start and then got 8 sleeves. Very good piece.
Dean Feiock -- Stock 5002
Dean Feiock is offline   Reply With Quote
Old 11-28-2018, 10:23 AM   #7
Lyn Smith
I will be staying away from the exotic 4 bolt main blocks,and the sleeved blocks because of the cost.I guess I just need to find a good used standard bore 305 block.Will check around here locally.Thanks for the info.
Old 11-28-2018, 01:05 PM   #8
Bruce Witherspoon
Bruce Witherspoon's Avatar
Liked 5 Times in 3 Posts
Lynn,
Talk to Bob Downing. I'm sure they have a barn full of them.
Bruce Witherspoon 3656 SS/KA
Bruce Witherspoon is offline   Reply With Quote
Old 11-28-2018, 01:59 PM   #9
Chipper Chapman
Chipper Chapman's Avatar
Liked 166 Times in 71 Posts
The 1996-2000 305 vortec blocks are supposed to be the best, but you would have to use a rear main seal adapter, just like many of the bowtie blocks had.
Chris Chapman
1969 Chevelle
NHRA F-G/SA 1090
