Old 12-08-2018, 12:30 AM   #1
gmonde
gmonde's Avatar
Liked 165 Times in 59 Posts
Default math class needed on valve springs
what is the math formula for a known spring rate to calculate seat and open pressure ?
spring rate is 370lbs @ 1.00"
closed valve spring installed heigh1.780
open valve spring height 2.237
seat pressure ?
open pressure ?
thanks in advance
Old 12-08-2018, 02:21 AM   #2
David Lee
Liked 346 Times in 126 Posts
Default Re: math class needed on valve springs
this might help
https://help.summitracing.com/app/an...ve-spring-rate
Old 12-08-2018, 09:57 AM   #3
Myron Piatek
Liked 138 Times in 51 Posts
Post Re: math class needed on valve springs
seat pressure ?
open pressure ?
thanks in advance
If you meant to say "open valve spring height 1.237" then the difference is .543"
370 rate x .543" lift = 200.91 lbs more than whatever you set/start with the installed height at.
You have to have a baseline height/pressure to calculate from, which the spring chart or actual test pressure will provide. That height is a variable based on valve stem length, +/std./- locks & retainers, spring seat machine work, depth of valve job seats.
LOCOMOTION Racing
Old 12-08-2018, 11:00 AM   #4
Chevy55
Banned
Liked 179 Times in 89 Posts
If you can afford it, this is the cats meow..............
https://www.summitracing.com/parts/l...+5ba26a96cdb6b
Wish I had it years ago!
Chevy55 is offline   Reply With Quote
Old 12-08-2018, 01:43 PM   #5
gsa612
gsa612's Avatar
Liked 280 Times in 139 Posts
What is the valve lift on the int. and exh.?. gsa612
Old 12-08-2018, 04:59 PM   #6
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
If you can find a comparable spring on the PAC Racing site, this link to their spring rate calculator might help.
https://www.racingsprings.com/index..../?sku=PAC-1224
Edit: Change the part number to your match.
Dale Shearon
68 Mustang 6394
Old 12-08-2018, 06:08 PM   #7
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
The basic formula is F=kX . F is the force , k is the rate , X is the difference in spring height from the length of the spring when it is not loaded .
Old 12-09-2018, 12:29 AM   #8
Eman
Liked 133 Times in 76 Posts
seat pressure ?
open pressure ?
thanks in advance
Is the spring rate 370lbs per inch? Is the installed height 1.780? Open height can't be more than closed, what is the free height of the spring?
Old 12-09-2018, 11:47 AM   #9
Kevin Panzino
Kevin Panzino's Avatar
Liked 778 Times in 142 Posts
This is correct.
To add to above, the spring rate is stated as the force generated per unit of compression. Ex: 1,000 Lbf/Inch, 1,700 N/cm etc.
Also, its spring FORCE, not pressure. Spring pressure is a common misnomer racers seem to always use, and it just wont die. Its entirely wrong. Its not a pressure, Its a force.
Kevin Panzino is online now   Reply With Quote
Old 12-09-2018, 10:11 PM   #10
gmonde
gmonde's Avatar
.457
