Old 12-25-2018, 10:12 AM   #81
Dwight Southerland
Dwight Southerland's Avatar
Liked 784 Times in 196 Posts
Default Re: The best "Dime Rocket" combos!
Originally Posted by Tom keedle View Post
soooo, what do you guys think about a 70 Hornet with a 232/ stick combo? I seem to have one that's just begging for SOMEBODY to build....it might have to be ne...
While it seems that would be good because of the 2-bbl carb, the '77 or '79 258 2-bbl makes more sense for only 5 more hp. they have 26 more cubic inches, bigger cam, better cylinder heads. Ed Fernandez and Jim Mantle have proven them as automatic combos.
Old 12-25-2018, 10:22 AM   #82
Billy Nees
Liked 7,922 Times in 1,758 Posts
Well, the newer 258s are better but if you have a 70 Hornet, I would say go for it! If you compare it to my 70 Chevy 230/140/140, everything is as good or better and I'm stuck with a 1bbl. and it ran pretty good.
Billy Nees 1188 STK, SS
Old 12-25-2018, 10:35 AM   #83
Tom keedle
Tom keedle's Avatar
Liked 8 Times in 7 Posts
the 232 is a single barrel carb motor...far as that goes, I've got a 73 258 out of a gremmy and a 77 258 that's out of a 77 amx (hornet) that are both 1 bbl engines. i'me wondering if it would be worth swapping cranks with the 232 so I could get a scattershield….kinda like my feet like to run a stick for the fun factor and BTW Dwight, I've got your nuts....i'll get them sent this week
Old 12-25-2018, 10:40 AM   #84
Billy Nees
OK?
70 232 lists 1bbl and 2 bbl both at 145 HP.
Old 12-25-2018, 10:55 AM   #85
Billy Nees
Originally Posted by john ancona View Post
Best (low cost) engine combo for a 1977 Nova
305 2v watch the year, the HP changes a bit.
Old 12-25-2018, 11:09 AM   #86
Tom keedle
Tom keedle's Avatar
OK?
I see that now...although a wcd ain't my favorite carb, I did learn a few things about them...it'll take some looking to find an intake...
Old 12-25-2018, 12:13 PM   #87
Liked 5,154 Times in 1,967 Posts
It's okay , but doesn't run in the 6 & 4 cylinder class (V/Stock )
Meanwhile , a 77 Maverick, 302 V8 is still at 137 hp! ..A 79 Mustang or Fairmont is @ 143 hp. All will make U/Stock, where the big index break comes in.
Old 12-25-2018, 01:02 PM   #88
farmco r/sa
Liked 147 Times in 54 Posts
After 87 post the dime rocket master Bob Shaw suspicously
absent. Merry Christmas and happy new year Bob.
Hope you and yours are well. Bob holds his cards pretty
close to his vest..
Correction. Did re-read and found Bob back on post #35..
Randy Hyman. Lakewood co. stk 5394
P/SA
farmco r/sa is offline   Reply With Quote
Old 12-25-2018, 01:18 PM   #89
farmco r/sa
Originally Posted by Bob Shaw View Post
Mark,
You have to remove the muffler and air cleaner and raise the fuel pressure a little,
Sounds easy enough..
P/SA
Old 12-25-2018, 01:29 PM   #90
I suppose, seeing it's Christmas, I ought to be more charitable.
Okay, you've got the car and want to race it. Better than sitting behind a keyboard all the time. I know that story.
Anyway, so what are your plans for this thing? Where will you test it at a reasonable altitude? Kearney is 300 miles, right?
How about the clutch? Trans and shifter? Rear end?
The reason I ask is because Stick shift / Dime rocket doesn't necessarily go together. You know , like jumbo shrimp? Rap music?
