#11 | |
Liked 231 Times in 107 Posts
#12 |
Liked 994 Times in 200 Posts
Here is what Mr.Bill Jenkins said about 265 blocks in his 1971 Chevy Power Guide."In the case of the 3-3/4 inch bore blocks,the best one to use is the original 1957 castings.These 57 blocks featured a heavier top deck or head surface for better strength and optimum gasket sealing. They also had the constant feed lifter gallery oiling,which is more desiable."
#13 |
Liked 799 Times in 236 Posts
Lyn, not sure where the budget is, but a sleeved pre '68 327 would be a great way to go. A savvy machine shop will have access to sleeves that are reasonably priced.
Neat project and car. ![]()
"That'll never work....." |
#14 |
Liked 18 Times in 10 Posts
I have a 57 block that ends with the letter C that has been magged and cleaned, Also have a brand new small journal 3 inch stroke crank.
57 blocks had no side motor mounts. |
#15 |
Side mounts did not show up until 1958.
Ed Wright 4156 SS/JA |
#16 |
Liked 20 Times in 15 Posts
The block I run in mine is a 3720991(1956 number) but it has the neoprene rear main seal so it must have been a service replacement unit. No side mounts.
The '57 265 is a 3731548 and the number on the passenger side(on the pad in front of the head) can be either a "C,CD or CE". Mine is a "CD" which I believe meant it came with a 3 speed overdrive manual transmission. The car it came out was a 2 door wagon. I think "CE" meant heavy duty clutch. I call it a "Poor Man's" Bow Tie block. Crank is part #3735236. None of the 265's I own have side mounts. Last edited by 55 Chevy; 01-09-2019 at 05:33 PM. Reason: Bad Grammar |
#17 |
#18 |
Liked 5 Times in 3 Posts
Bruce Witherspoon 3656 SS/KA |
#19 |
Thanks for the link Bruce.I have seen 265 blocks/ complete engines from $100. to $1399. Depends on if it is for a Corvette or not.LOL I have a line on a 548 block that the owner says sonics .300 on the thrust side.Hope to get that one.Thanks everyone for all the info, and interest.I will let you know how it turns out.Will post build on the Racer Build Up thread.
#20 |
Liked 71 Times in 23 Posts
Lyn a friend of mine has some 265 engine parts for sale. 991 block, heads, crank and manifold. I told him to look you up on here. His name is Rob Fisher
Monte Howard 3209 STK, 3208 SS |
