#81 | |
The turbo cars had a side draft Rochester. Other models had a 4GC. The suspension is similar to a Chevelle, but the coils are on the trailing arms, like a Fox body. I doubt anything modern would bolt it to replace the Jet-a-Way (Slim Jim) Probably could use a later Land Rover block that might have the B.O.P. pattern.
#82 |
Liked 7,866 Times in 1,750 Posts
You're (of course) right about the carb. Same as turbo Corvair, wasn't it?
As far as the alcohol injection, didn't they inject it into the turbo to cool it?!? Looking at the pics, I guess they inject it into the carb..
Billy Nees 1188 STK, SS I'm not spending 100K to win 2K Last edited by Billy Nees; 01-20-2019 at 07:13 PM. Reason: I'm dumb |
#83 | |
Rather than lowering the compression, Olds decided to inject the fluid to cool the combustion.. I'd suggest using an MSD Boost Master timing retard control with this one ;-)
#84 |
Liked 557 Times in 217 Posts
https://forums.aaca.org/topic/108020...draft-rochest/. To complicated for 1963. I do recall at least one that came in the station I worked at. Plagued with problems. Engine and trans. The Slim Jim was poor in everything GM put it in.
#85 |
Well, seeing as it's 3* outside and the wind is blowing like a banshee AND boredom is setting in,
how about a 63 Chevy II 4cyl 153/90/90 for W/S or W/SA at 2330? Same basic engine as my 230s minus 2 cylinders. I guess the problem would be finding one but it would be fun with a stick and probably pretty quick with a metric!
#86 | |
Liked 684 Times in 289 Posts
A nice life for a metric, behind one of those... Mike A114 |
#87 |
No, kinda like the "Iron Dukes" grandfather.
#88 |
ok,
Iron Duke late 1960`s? I recall a 68 or 69 Nova w/4 banger, and a guy called it an Iron Duke. Last edited by Mike Jones; 01-21-2019 at 01:02 PM. |
#89 |
Liked 783 Times in 195 Posts
Weren't those used in marine applications a lot?
#90 |
I think they were...
