#81 | |
The turbo cars had a side draft Rochester. Other models had a 4GC. The suspension is similar to a Chevelle, but the coils are on the trailing arms, like a Fox body. I doubt anything modern would bolt it to replace the Jet-a-Way (Slim Jim) Probably could use a later Land Rover block that might have the B.O.P. pattern.
#82 |
You're (of course) right about the carb. Same as turbo Corvair, wasn't it?
As far as the alcohol injection, didn't they inject it into the turbo to cool it?!? Looking at the pics, I guess they inject it into the carb..
Billy Nees 1188 STK, SS I'm not spending 100K to win 2K Last edited by Billy Nees; 01-20-2019 at 07:13 PM. Reason: I'm dumb |
#83 | |
Rather than lowering the compression, Olds decided to inject the fluid to cool the combustion.. I'd suggest using an MSD Boost Master timing retard control with this one ;-)
#84 |
Liked 544 Times in 213 Posts
https://forums.aaca.org/topic/108020...draft-rochest/. To complicated for 1963. I do recall at least one that came in the station I worked at. Plagued with problems. Engine and trans. The Slim Jim was poor in everything GM put it in.
#85 |
Well, seeing as it's 3* outside and the wind is blowing like a banshee AND boredom is setting in,
how about a 63 Chevy II 4cyl 153/90/90 for W/S or W/SA at 2330? Same basic engine as my 230s minus 2 cylinders. I guess the problem would be finding one but it would be fun with a stick and probably pretty quick with a metric!
#86 | |
Liked 684 Times in 289 Posts
A nice life for a metric, behind one of those... Mike A114 |
#87 |
No, kinda like the "Iron Dukes" grandfather.
#88 |
ok,
Iron Duke late 1960`s? I recall a 68 or 69 Nova w/4 banger, and a guy called it an Iron Duke. Last edited by Mike Jones; 01-21-2019 at 01:02 PM. |
#89 |
Liked 783 Times in 195 Posts
Weren't those used in marine applications a lot?
#90 |
I think they were...
