Liked 37 Times in 33 Posts
Looking for input on the Renegade RM K-16 Drag Elite specifically. I have been running the VP Q-16 for the past 4/years but I am thinking about switching to the Renegade.
I know both are "oxygenated" fuels., both need plenty of volume and both are good with higher compression naturally aspirated engines. Is there a front runner out of the two or not? Just curious, Thanks. |
Liked 8 Times in 6 Posts
Try X16 car stayed a bit more consistent then Q.
Class Racer Magazine Writer Super Comp A197 |
So this X16 is VP? The problem I was having with the VP Q16 was I just could not get enough fuel too a couple of the cylinders. Even with the biggest jet I could find.
Liked 292 Times in 147 Posts
What are you using for a carburetor?
I would be looking at decreasing the high speed air bleed size if you have increased to the "largest available" jet and saw no improvement. You don't have a fuel issue, you have a carburetor issue. |
Steve,
I run two 3/circuit 1150 Quick Fuel carburetor's. The air bleeds that I'm currently running are as follows: Idle-47 Inter-85 High-28 |
Did you lose any mph when you jetted up?
Based on the numbers you posted, your intermediate circuit may be too large creating the lean condition at WOT, as the intermediate is still in operation in conjunction with the high speed circuit at WOT. |
Steve,
Didn't lose mph. Kept going bigger on the jets to get away from the motor running lean (13.7-13.8) on the big end. I have O2 sensors on all 8 tubes. So your thinking is to go a little richer on the inter.? Say like an "80" Thanks..... |
Liked 397 Times in 153 Posts
You could also give it a bit more fuel through the intermediate fuel feed, as well as the 80 for the bleed. Test and test again. The high speed can also be brought down to 26, it will make a difference.
Phil Molski PMR Performance S/C 1623 |
pmrphil,
Appreciate it.... |
Liked 46 Times in 17 Posts
Hey Shake.......Renegade and Q smelled the same, preformed the same on dyno and track....only difference was color, but I only run one large four barrel......Howie
