Old 01-27-2019, 05:06 PM   #11
J&S Racing
Liked 327 Times in 87 Posts
Default Re: Radiator
Originally Posted by ken robinson View Post
Why dose the Be-cool radiator cost more than the champion radiator are they that much better ? Which radiator did some of try and why ?
I went with the champion for my build... super nice radiator and they were great to work with, I had them replace the ends with AN fittings. They also have a nice shroud.
Old 01-27-2019, 08:19 PM   #12
Brett Albert
Ken,
I ended up going with an aluminum radiator from DeWitts for my 71 Nova. I ordered it painted black. They make a nice product and it fit well with my factory hardware.
Brett Albert
Stock 1459
Brett Albert is offline   Reply With Quote
Old 01-29-2019, 02:14 PM   #13
engineguy
According to NHRA Rulebook, Stock classes:
"Full size radiator mandatory for body used. Aluminum radiators permitted; must retain stock dimensions and appearance. Cutting, denting or elimination of any body, fender, radiator or grille panels prohibited."
Basically, this means that a top/bottom tank (vertical flow) radiator cannot be replaced with a cross-flow radiator and the hose inlet/outlet located must be in the original configuration. Most cars were available with heavy duty radiators, which typically had additional rows of tubes, therefore I don't think that there is any restriction on the thickness of the radiator core used.
engineguy is offline   Reply With Quote
Old 01-29-2019, 04:00 PM   #14
ken robinson
Liked 225 Times in 88 Posts
Main thing it's not a round track or street car so you dont need the 3or 4 row core , so a 2 row should work wright . The cost is very different between different makes so is it a quality thing or paying for the name ?
Old 01-29-2019, 04:33 PM   #15
Joe Martens
Joe Martens's Avatar
Liked 198 Times in 71 Posts
Ken, check out Spectra Radiator. I used one on my car, direct factory aluminum replacement and very reasonable, and good fit. I believe any NAPA can get them. Also, keep in mind most aluminum radiators I have seen have 1 inch cores vs 3/4 inch cores like most factory radiators.
https://ecat.spectrapremium.com/products/CU337
Hope this helps.
Joe Martens AA/Stock 3969
Joe Martens is offline   Reply With Quote
Old 01-29-2019, 06:42 PM   #16
Mike Jones
Liked 684 Times in 289 Posts
Originally Posted by HandOverFist View Post
Aluminum in the El Camino with zero questions thus far. Painted black one probably could not tell from factory.
Boy does that look nice, Rich...
MJ
