#11 | |
Liked 364 Times in 138 Posts
Dave Turner SS/GT #1153 |
#12 |
Liked 19 Times in 12 Posts
Gotcha! Thanks
Mitch Beri- The Motor City 1985 GT- “Stock-ish” 5.0 motor, AOD/ trans brake. 12.68 @ 101.31mph. https://www.facebook.com/groups/FOXBODYFLEAMARKET/ |
#13 | |
Liked 886 Times in 238 Posts
Especially on a car with steep rear gears .
#14 |
Liked 223 Times in 73 Posts
That's what I did too, I don't think I've come close to activating at the top end yet. But I do have a switch already installed, and putting it inline with power to the pressure switch is a good idea. I might try that some time. I put that switch in before I encountered the "unbroken wire" rule and never hooked it up.
#15 |
Liked 5,138 Times in 1,961 Posts
I'm sure I've posted this before.
Release was in the brake pedal.The system only worked with the shifter in low gear . Not possible to leave off the micro switch in low. I suppose someone could try to pull a fast one and leave in 2nd with an auto upshift deal. Still would be kind of awkward to use the switch (and the pedal button) on the line. I never had a problem..No. 1 Q, record holder, etc. ![]() ![]()
#16 |
You don't want the limiter coming on at the finish line..even accidentally .
You can get the boot for that.
#17 | |
Liked 53 Times in 38 Posts
#18 | |
Liked 133 Times in 76 Posts
I tend to scrub the brakes before the stripe to tighten it up, doing this with my foot on the throttle. If I didn't have a way to shut the 2 step off it would stutter at the top end. I have a switch that controls the power to the brake pressure switch and a small LED on the dash to show when the brake pressure activates the 2 step so I know I'm on the brake hard enough at the starting line. I've thought about using a high gear pressure switch on the trans that would open the power circuit in high gear. |
#19 | |
#20 | |
