Old 02-22-2019, 05:44 PM   #1
ScottHall
Default SS/AH Parts and Lots of Rims For Sale
I have a parts list taken from a shop in New Jersey. I am the not the final seller, but the middle man. I have photos of everything on this list, and I have personaly touched and seen each part. When I say the parts are brand new, in most cases, it is in the original box.
If you want photos or more info, email me at scotth115a@gmail.com and referance the # of the parts you inquiring about. All prices do not and will not include shipping. Checks perfered, Paypal will have the 3% added.
#23 Ford 9", Gleason Ring & Pinion, 40‐spline, 1440 Billet Yoke, Mark Williams Housing, Ceramic Bearings, Used, 5.40 ratio $4,000
#24 Ford 9", Gleason Ring & Pinion, 40‐spline, 1440 Billet Yoke, Mark Williams Housing, Ceramic Bearings, Used, 5.50 ratio $4,000
#25 Ford 9", Gleason Ring & Pinion, 40‐spline, 1440 Billet Yoke, Mark Williams Housing, Ceramic Bearings, Used, 5.43 ratio $4,000
#26 Ford 9", Gleason Ring & Pinion, 40‐spline, 1440 Billet Yoke, Mark Williams Housing, Ceramic Bearings, Used, 5.29 ratio $4,000
#27 Ford 9", Gleason Ring & Pinion, 40‐spline, 1440 Billet Yoke, Mark Williams Housing, Ceramic Bearings, Used, 5.33 ratio $4,000
#28 Ford 9", Gleason Ring & Pinion, 40‐spline, 1440 Billet Yoke, Mark Williams Housing, Ceramic Bearings, Used, 5.25 ratio $4,000
#29 Ford 9", Gleason Ring & Pinion, 40‐spline, 1440 Billet Yoke, Mark Williams Housing, Ceramic Bearings, Used, 5.67 ratio $4,000
#30 Ford 9", Gleason Ring & Pinion, 40‐spline, 1440 Billet Yoke, Mark Williams Housing, Ceramic Bearings, Used, 5.63 ratio $4,000
#31 Ford 9", Gleason Ring & Pinion, 40‐spline, 1440 Billet Yoke, Mark Williams Housing, Ceramic Bearings, Used, 5.38 ratio $4,000
#32 C&R Chiller 14‐ gallon with hoses and ends $2,000
#33 Weld Magnum Rear Rims, non‐beadlock, 15x14, 5 x 5, 5" back space, drilled for screws, never bolted up $1,500
#34 Weld Magnum Rear Rims, non‐beadlock, brand new, 15x14, 5x5, 6" back space $1,500
#35 Weld Magnum Rear Rims, beadlock, brand new, Gold Ring, 15x15, 5x5, 6" back space $2,000
#36 Weld Magnum Rear Rims, beadlock, brand new, Black Ring, 15x15, 5x5, 6" back space $2,000
#37 Pro Trans 727 HEMI Bellhousing, 904 internals, Built for SS/AH $4,500
#38 Pro Trans 727 HEMI Bellhousing, 904 internals, Built for SS/AH $4,500
#39 Pro Trans 727 HEMI Bellhousing, 904 internals, Built for SS/AH $4,500
#40 Pro Trans 727 HEMI Bellhousing, 904 internals, Built for SS/AH $4,500
#41 Pro Trans 727 HEMI Bellhousing, 904 internals, used, Built for SS/AH, 2.32 ‐ 1.51 ratio $4,500
#47 Weld Magnum Rear Rims, non‐beadlock, 15x15, 5 x 5, 6" back space, used $1,100
#48 Weld Magnum Rear Rims, beadlock, Black Ring, 15x15, 5x5, 5" back space, new $1,500
#49 Weld Magnum Rear Rims, non‐beadlock, 15x15, 5 x 5, 6" back space, used $1,100
#50 Weld Magnum Rear Rims, non‐beadlock, 15x15, 5 x 5, 6" back space, new $1,100
#51 Weld Magnum Rear Rims, non‐beadlock, 15x15, 5 x 5, 6" back space, used $1,100
#54 RJ Race Cars 8" Clutch Disk Cutter, Brand New, Pnematic Arm $3,60
ScottHall is offline   Reply With Quote
Search this Thread:
Advanced Search
