Old 02-26-2019, 10:33 PM   #1
SDT1DYI
Liked 456 Times in 148 Posts
Default Wheel Studs
Have Moser axles 5/8" 18 TPI RH knurl .685, pressed in studs. Need longer studs . Moser only offers 2 1/2" under the head length. Need 3 1/4". Looked on Summit / Jegs , ARP, others. Nothing in .685 knurl. Any racers run in to this and solved it, short of replacing the axles???
Steve Teeter STK 6380.
SDT1DYI is offline   Reply With Quote
Old 02-26-2019, 11:25 PM   #2
gsa612
gsa612's Avatar
Liked 280 Times in 139 Posts
Default Re: Wheel Studs
Moroso has a 5/8 stud 3" # 46240 with a .672 knurl,or a 3" 1/2 stud with a .685 knurl #46190.Also M-W has a 4" drive stud kit in 5/8,but the hole in the axle is too big to tap at .685.The thread dia.is .625 for the 5/8 screw in stud. gsa612
Old 02-26-2019, 11:52 PM   #3
SDT1DYI
I will look at those part numbers, thks.
Old 02-27-2019, 12:00 AM   #4
SDT1DYI
46190. Is shown as a 1/2" 20 stud? I Need 5/8".
Steve Teeter. STK 6380
Old 02-27-2019, 10:47 AM   #5
Alan Nyhus
Liked 800 Times in 237 Posts
These won't work?
https://www.jegs.com/i/JEGS/555/65152/10002/-1
"That'll never work....."
Old 02-27-2019, 01:43 PM   #6
gsa612
gsa612's Avatar
Looks like these may work,the only thing is there a coarse thread (11) and yours are 18.Just have to get new nuts. gsa612
Old 02-27-2019, 06:52 PM   #7
gsa612
gsa612's Avatar
What type of rear wheel are you running?. gsa612
Old 02-27-2019, 08:35 PM   #8
SDT1DYI
Bogarts came on the car. I purchased some Weld Pro Stars for a set of spare rim/tires. The Welds have a 1/2" thicker hub.
The 11 to 18 threads per inch change, could be the solution, need to understand how it effects the rim, and stud torque.
Old 02-27-2019, 09:31 PM   #9
FED 387
Liked 336 Times in 183 Posts
not sure if this will work but take a look at a Dorman 610-418 or GM 15725054 stud --these are used on GM duallies rear ends
Old 02-27-2019, 10:35 PM   #10
gsa612
gsa612's Avatar
When you put the bogarts on with the 5/8 studs that you have,is there a lot of space between the wheel stud hole and the stud.Does the wheel move back and forth?.The od.of the 5/8 stud is .625 ,and the hole if you were using a shank nut would be .685.The only nut that seems to be available for the 5/8 course stud is flat on the back were it presses against the wheel.The cars that I've seen using 5/8 studs are using a M-W stud kit,that has a 4" stud that threads in the axle flange.then there is about a 2". 685.bare shank in the center
that goes thru the wheel and is tight inside the hole.It then has a threaded portion that you put a spacer and nut on.The Jegs 5/8 course stud might be better suited for a circle track car with a steel wheel,were you would use a beveled nut to center it in the hole.See what you come up with and keep us posted. gsa612
