Old 02-27-2019, 02:14 PM   #11
Aubrey N Bruneau
Aubrey N Bruneau's Avatar
Liked 7 Times in 3 Posts
Send a message via Yahoo to Aubrey N Bruneau
Default Re: Mounting weight in car?
HHMMM...
I realize that I know almost nothing... but
but
SOMEBODY has to ask this
Why the dedication to making the car so much heavier ? ? ?
How I see it
A station wagon, by it's very design, already has a weight transfer advantage.
Obviously, the lighter car is faster.
The lighter car is easier on chassis parts... and even the body, if the intended added weight isn't in the form of structural improvement.
Why not go up a class ?
Besides, faster is funner !
just say'n
Aubrey N Bruneau 6409 C/S
62 BelAir sport coupe, 409 HP 409
Aubrey N Bruneau is offline   Reply With Quote
Old 02-27-2019, 02:33 PM   #12
Originally Posted by Aubrey N Bruneau View Post
HHMMM...
but
How I see it
just say'n
Good question. Now here's the answer :
First of all , a lot of racers don't pay any attention to the lower Stock classes. They do indeed ,think faster is funner ( and much more expensive..MY) Also ,they're convinced they can't win much , without being a chaser, running in the 10's. However, the fact remains, you have to hit the tree and run close, if you ever want to win anything, without relying on luck.
Okay..On to the answer.
T/SA index ,14.40 @19 lbs. per.
U/SA index , 14.85 @ 20 per.
Difference , .45 seconds.
At 204 hp, to go from 19 to 20 lbs. per, that is the amount of weight you would add.
You can probably extrapolate it from there.
Old 02-27-2019, 02:50 PM   #13
Jeff Stout
Liked 706 Times in 283 Posts
To run T I need to be 4103 lb.
To run U I need to be 4310 lb
Currently the car with driver and 3 gallons of gas is 3880 lb.
Yes a wagon will have good weight transfer but I need to meet minimum weight to fit in class. With the extra weight in the rear it will really transfer.
Old 02-27-2019, 03:26 PM   #14
Aubrey N Bruneau
Ah yes, I didn't realize that about T / U .
Makes sense now.
