Old 03-01-2019, 04:29 PM   #21
Coleydog
Liked 53 Times in 38 Posts
Default Re: Wheel Studs
Quite a difference between 1/2 & 5/8,
Proof load for grade 2-5-8 for 1/2 stud = 8800-13600-19200
For 5/8 stud = 14100-21800-30700, a good 30% + - stronger across the board
I always heard not to use the grade 8 because it's to hard & brittle, use grade 5. Not sure what they use from Strange or Moser.
Old 03-01-2019, 04:31 PM   #22
gsa612
gsa612's Avatar
Liked 280 Times in 139 Posts
I don't know about Moser but Strange will drill and tap their axles from 1/2 to 5/8 as long as the have not been welded on, Studs tacked etc. I had mine done by Strange about ten years ago and the cost was minimal. They fit the wheels perfectly when I got them back. Turn around was very quick as well.
He's going to need 10 new holes indexed,drilled and tapped.The current knurled stud hole is bigger than a 5/8 threaded stud.Hope it don't have 1" lightening holes between the existing holes then your SOL. gsa612
Old 03-01-2019, 04:36 PM   #23
gsa612
gsa612's Avatar
Originally Posted by ss3011 View Post
Just asking , but if 5/8 is .625" and your axles have a .685 knurl , how do you tap them for a 5/8 stud ?
Post # 2 lol...gsa612
Old 03-01-2019, 05:30 PM   #24
jmcarter
jmcarter's Avatar
Liked 3,235 Times in 984 Posts
My axles were drilled for both 1/2 and 5/8 screw in studs. The axle flange still isn’t the weakest link.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 03-03-2019, 08:01 AM   #25
chris ok
chris ok's Avatar
Liked 46 Times in 29 Posts
Contact Mark Williams.
They solved my moser problems that moser just could not.
Many length 5/8 studs, washers, lugs and associated parts.
chris ok is offline   Reply With Quote
Old 03-06-2019, 01:12 PM   #26
Run to Rund
Liked 55 Times in 28 Posts
Grade 8 is stronger across the board, including tensile. My Moser axles are tapped for 5/8" x 18 thread bolts, so I just buy long enough bolts. If the wheel hole is much bigger than 5/8", you could get sleeves or find studs with larger unthreaded areas. People who think grade 5 is better, why does ARP make bolts and lug nuts?
Old 03-06-2019, 04:42 PM   #27
Coleydog
Something like, the harder it gets the more brittle it becomes.
