Old 03-07-2019, 12:29 PM   #21
Ed Wright
Ed Wright's Avatar
Default Re: question on rings ?
Napier style second rings help with oil control, and require less oil ring tension. Using a fish scale to measure drag, I've been down to 4.5lb drag, but got some blue smoke at times. 6 lbs seems to run just as fast, with no blue smoke. 4" bore.
Ed Wright 4156 SS/JA
Old 03-07-2019, 01:45 PM   #22
John Dinkel
Liked 263 Times in 68 Posts
Thumbs up Re: question on rings ?
Adger, I'm interested too. maxwedgejohn@aol.com
John Dinkel 3295 STK
John Dinkel is offline   Reply With Quote
Old 03-07-2019, 06:07 PM   #23
Bill Bogues
Bill Bogues's Avatar
Liked 169 Times in 53 Posts
Smile Re: question on rings ?
If you're trying to get by cheap, just use correct size moly filled top ring with shim stock behind it to space ring close to edge fo ring land on piston. Use next undersize plain iron 2nd ring as is. Use next undersize oil ring expander with correct size oil rails. This works pretty good for cheap ring package on sbc.
Bill Bogues 4696 STK
Bill Bogues is offline   Reply With Quote
Old 03-08-2019, 11:03 AM   #24
Dan Lattimore
Liked 154 Times in 37 Posts
123
66W30POST
Dan Lattimore is offline   Reply With Quote
