Old 03-12-2019, 07:08 PM   #1
Jim Hanig
Liked 99 Times in 49 Posts
Default bellhoushing
How many stick shift guys check there bellhousing alignment, how far off can it be.
Old 03-12-2019, 07:38 PM   #2
Rory McNeil
Default Re: bellhoushing
Always check them, never had one that was dead on, or close to it, out of the box. A bit of a pain, but always a good idea to check and correct. When I get the bellhousing dialed in with offset dowel pins, I always drill and tap the block for small set screws so that the pins won`t get knocked out of position during bellhousing re & re . Obviously zero is ideal, but I try to keep it under .005".
NHRA 6390 STK
M/S 85 Mustang
Old 03-12-2019, 09:41 PM   #3
Stephen & Horace Johnson
Liked 163 Times in 53 Posts
I have 2 QT's on my cars both were dead on
Stephen Johnson #2162
Horace Johnson #2167
Stephen & Horace Johnson is offline   Reply With Quote
Old 03-12-2019, 10:08 PM   #4
Nmbr1GMfan
I have found QT's to be really good as well.
Todd Greene
Old 03-12-2019, 10:10 PM   #5
Rory McNeil
Stephen, do you have a QuickTime in the Fairlane? If so, with what clutch? I had heard that on a FE Ford the QuickTimes were not deep enough to work with a Long style pressure plate with a 10 or 10 1/2" disc, unless you stacked up block plates to get enough room. What is your experiance with the FE?
NHRA 6390 STK
M/S 85 Mustang
Old 03-12-2019, 11:43 PM   #6
T Ames
T Ames's Avatar
Liked 125 Times in 33 Posts
Hello Jim. Agree with Rory on being within ~.005. I like the Browell alignment tool and also the RobbMC offset dowels.
T Ames is offline   Reply With Quote
Old 03-13-2019, 10:32 AM   #7
Run to Rund
Liked 54 Times in 27 Posts
I have had to use offset dowels and also correct in and out being off square. I use Lakewood dowels drilled and tapped 5/16 x 18 so I can remove them with a slide hammer. I have gotten some pretty bad alignments to within .001" by carefully orienting the dowels. Yes, I also have found QT to be much better than the old Lakewoods, but still the block is often not close enough.
Old 03-13-2019, 02:23 PM   #8
Greg Reimer 7376
Liked 719 Times in 220 Posts
Cool Re: bellhoushing
A machinist I knew, one of those guys who must stay up nights thinking about new ideas and stuff, took a very accurately machined,decked, squared, line honed and ready to go block, and just for something else to do, decided to check and see if the rear mating surface of the block was accurate, in this, he meant 90 degrees perpendicular to the center line of the main saddles. He put a ready to go crank in it, then a flywheel which he properly torqued, and checked for run out,it was perfect, but when he checked the distance from the rear face of the flywheel to the surface of the block, it wasn't 90 degrees from the crankshaft c/l. In other words, the bell housing flange wasn't the least bit flat, or accurately machined.Now,dealing with a cast iron block that came from the furnace and was originally machined at the OEM engine plant long before it ever was a seasoned casting, that makes sense. I remember cars when I worked in dealers in the mid-late '70s once in a while you would get one with a cracked flex plate. If it's absorbing run out every revolution,how long can you expect it to last? You 4 speed racers, and I love seeing them, trying to get an accurate result using offset dowel pins and God knows what else it might take to achieve an accurate result from a hydroformed or stamped part like that scatter shield,could have a whole host of inaccuracies to deal with. In short, has anybody ever had clutch and flywheel issues due to inaccurate machining of the rear face of the block on back? I'll bet we have,and don't know it!!
Old 03-13-2019, 03:27 PM   #9
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
Originally Posted by Greg Reimer 7376 View Post
. . . In other words, the bell housing flange wasn't the least bit flat, or accurately machined.. . .
X2!
Dwight Southerland is online now   Reply With Quote
Old 03-13-2019, 03:27 PM   #10
Jim Caughlin
Liked 805 Times in 245 Posts
Totally correct, you have to check for parallel before you start checking for run out, I've seen this problem also.
On another note regarding Quicktime, thank you very much for changing the flange bolt pattern and not saying anything. I use a small block Ford bellhousing from Quicktime which bolts to an adapter plate (that I fabricated) to fit my 2.3 Ford motor. I bought a new 'duplicate' bellhousing from them last year and the entire flange arrangement had been changed. I had to rework my adapter plate along with the chassis cross member to make everything fit. As a general rule, I like the Quicktime quality but sure wasn't happy about the unnecessary redesign. Also, their prices went through the roof when they got bought out a few years back.
Jim Caughlin is offline   Reply With Quote
