Old 03-15-2019, 12:01 PM   #1
Makinchips
Default Torque converter slippage
What percentage does an 8" a/sa or b/sa converter slip approx.
I'm considering upping the rear gear in my bracket car which runs low 10s presently but am unsure of the rpm gain from converter slip.
Makinchips is offline   Reply With Quote
Old 03-16-2019, 09:28 AM   #2
Liked 1,892 Times in 423 Posts
Default Re: Torque converter slippage
We get 4%-6% with an 8" ATI.
Old 03-17-2019, 02:12 PM   #3
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
How about 10 inch? I need a stall of 5000 - 5600 for my Impala SS
Old 03-17-2019, 03:27 PM   #4
gsa612
gsa612's Avatar
Liked 280 Times in 139 Posts
How are you going to get that stall from a 10" converter with low hp?. gsa612
Old 03-17-2019, 08:20 PM   #5
gmonde
gmonde's Avatar
Liked 165 Times in 59 Posts
you would be hard pressed to get that from a 9"
8" is the area ,, tune the converter from there
Old 03-17-2019, 08:41 PM   #6
STK1217
STK1217's Avatar
Liked 10 Times in 7 Posts
ATI told me as much as 9% for a PG 8" 5800 rpm 1.76 first gear 3200 lb. 509 BBC 800 hp was not uncommon.
STK1217 is offline   Reply With Quote
Old 03-17-2019, 10:50 PM   #7
Dan Fahey
Dan Fahey's Avatar
Thanks...my car is a 1995 Impala SS LT1.
Weight 4150 lbs, stock rods, limited to about 7000 rpm.
Trying to understand the latest generation of converters.
Determining best gear to chose for top end.
5% slippage more gear, 8% slippage less gear.
D
Old 03-18-2019, 01:50 PM   #8
Mike Pearson
Mike Pearson's Avatar
Liked 1,946 Times in 587 Posts
D
Dan
The more gear that you have in the car the less the converter will slip. Talk to ATI about your combo and they will get you in the ballpark on the first try. Then you can make some changes as you move forward and test the car. Talk to Charlie at ATI. He is real familiar with the class racing stuff. You really can’t go wrong with them.
Mike Pearson 2485 SS
Old 03-18-2019, 09:58 PM   #9
Mike Rietow
Mike Rietow's Avatar
Liked 30 Times in 16 Posts
There is an equation. Need this info.
Tire size + observed roll out? + bias or radial?
Current gear
New gear
The current rpm and mph at the stripe.
It'll tell exactly what rpm you'll cross with the new gear , as well, as converter slip percentage with the current and new gear.
7x S/Pro 'Sunshine" http://ottm.store
https://youtu.be/I8QWEaqeFRw
Mike Rietow is offline   Reply With Quote
