Old 03-19-2019, 10:55 AM   #1
Coleydog
Liked 53 Times in 38 Posts
Default Carpet for back seat
I need a source for carpet to cover where the back seat went. Or are there other options to cover that area? What have you used? I wanted to use the seats but the cage bars makes it impossible. Thanks
Mike
Old 03-19-2019, 11:31 AM   #2
jmcarter
jmcarter's Avatar
Liked 3,221 Times in 980 Posts
Default Re: Carpet for back seat
I’d reach out to Mr, Derby City...he probably has a pattern that would fit. I’ve got the super light weight carpeting in the back but it’s showing it’s age. That is who I’ll contact when I’m traveling through there.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 03-19-2019, 11:54 AM   #3
Mark Ruset
Mark Ruset's Avatar
Liked 43 Times in 29 Posts
Found a roll of black carpet at Home Depot, I believe it's original use was for covering stereo speakers, it is relatively inexpensive and wide enough to cover the are of a rear seat,
Mark Ruset 2048 STK
Mark Ruset is offline   Reply With Quote
Old 03-19-2019, 03:29 PM   #4
Mike Pearson
Mike Pearson's Avatar
Liked 1,946 Times in 587 Posts
it doesn't necessarily have to be carpet. It just has to be upholstered in some way. Not bare metal.
Mike Pearson 2485 SS
Mike Pearson is online now   Reply With Quote
Old 03-19-2019, 03:57 PM   #5
JHeath
JHeath's Avatar
Liked 370 Times in 101 Posts
I found some fabric on ebay , looks like the stuff they use in the trunks of newer cars.
Jerry Heath
I/S '93 Cobra
FS/J 2010 Mustang "Ebay CJ"
Old 03-19-2019, 05:29 PM   #6
Timetraveler
Liked 12 Times in 6 Posts
If you don't need a roll bar because of class but you need a firewall because you have a fuel cell can you carpet over the firewall or do you have to put the back seat in?
Timetraveler is offline   Reply With Quote
Old 03-19-2019, 07:17 PM   #7
Coleydog
No way I can get the seat installed unless I cut them in four pieces, back and bottom. Back "could" be done but bottom, too many cuts. I really wanted them back there for looks. I have cut foam blocks to fit (in pieces) then just the covers over those. Easy to conture with a grinder then hot glue or cement. Just need an agile Asian to get in there to work between those monkey bars, way beyond my fat butt.
Mike
Old 03-19-2019, 08:12 PM   #8
Dave Gantz
Liked 251 Times in 125 Posts
We did this on a car several years ago. It conformed to the various shapes and curves. We glued it down.
Old 03-19-2019, 09:00 PM   #9
FED 387
Liked 333 Times in 180 Posts
Go to a fabric store and buy "felt" or a similar product in a color that matches the interior cut it to fit and use aerosol adhesive to make it stick. Maybe do it for $10-15 for materials
Old 03-19-2019, 11:45 PM   #10
Coleydog
Good ideas so far, I'll look into these.
