Old 03-19-2019, 02:02 PM   #41
Don Braun
Default Re: NHRA "FIXED" Factory Showdown
the chassis certs are @ 7.50 for current FSS cars, I wonder when they'll eclipse that ??
Don Braun is offline   Reply With Quote
Old 03-19-2019, 02:20 PM   #42
Bobby Lundholm
Liked 127 Times in 49 Posts
Originally Posted by fastlane View Post
I think you will find the cost to buy that car and build it to where it needs to be to be competitive is closer to $225,000
That's even worse. I was basing my estimate off of buying the car, pulling the engine and trans to have them gone through.
Bobby Lundholm 3516 G/SA
Bobby Lundholm is offline   Reply With Quote
Old 03-19-2019, 04:25 PM   #43
Irace007
Liked 17 Times in 12 Posts
Originally Posted by Ralph A Powell View Post
No not our beloved NHRA! It will go the way of PRO Stock already some else pays. It will be the elminator of the HAVES and HAVE NOTS,
It already is !
Marty Hanft
Irace007 is offline   Reply With Quote
Old 03-19-2019, 05:52 PM   #44
BG56
Liked 295 Times in 111 Posts
Originally Posted by Bobby Lundholm View Post
I completely understand that. As with Pro Stock they aren't in it to win money, but at least Pro Stock gets $25,000. Granted that doesn't cover the costs of their program either but it does look a lot better than $1,500. What about Laughlin winning $50,000 for his small tire race win at Lights Out? If you made it $15,000 to win in Factory Shootout wouldn't even more racers show up?
BINGO! Those other races with nice purses are what NHRA can't compete with and are losing racers to. Pro Stock is almost irrelevant in the scope of things. FS/XX might be for (fun) but how long will they stick with it for (no) return? Like an old Pro Stock racer and friend says "Want to make a small fortune racing? Start with a Big one!"
Old 03-19-2019, 07:09 PM   #45
fastlane
Liked 53 Times in 20 Posts
Just a basic cost to be competitive in Showdown
new car $130,000
Build a showdown engine $40,000
Showdown Trans and convertor $15000
Update cage to 7.50 spec $9000
full racepack $8000
second set wheel tires $3500
Lighten car add weight to back $500
different third member $2500
Proper shifter $1000
Suspension $10,000
in car communication $1500
Assorted other things needed $3000
Spare parts $$$$$$$
Total at least $225000 You can do it for a bit less but you will not qualify and may not even at that cost either. And constant work needed after each event. And add in a trailer and Motor home you can add $250,000-$400,000
It is not a class for the average sportsman.
fastlane is offline   Reply With Quote
Old 03-19-2019, 08:19 PM   #46
Mike Jones
Liked 684 Times in 289 Posts
JDM Engineering once posted on here, that one of his customers had 100K in the trans. I asked if he meant 10K, he said nope.
MJ
Old 03-19-2019, 08:36 PM   #47
fastlane
MJ
Seems high you can buy a Coan or Joel Showdown trans for 10-11 grand and a aluminum light weight bolt together converter for 5-6 grand Maybe he had it gold plated.
Old 03-19-2019, 09:15 PM   #48
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
Damn I wish Pure Stock was back.
Getting it set up to make STOCK is $10000.
Another $10000 to make it competitive with other care in class
And that is cheap.
To really make it all up requires frame up restoration to benefit from all the rules. Weight shifting, special bearings, REM, metal treatment. ETC
The concept of Stock left reality a long time ago.
They are Comp cars with a smaller cam.
Old 03-19-2019, 09:56 PM   #49
Todd Hoven
Guest
Posts: n/a
This has what to do with Factory Showdown racing?
And that is cheap.
Old 03-20-2019, 12:32 AM   #50
JHeath
JHeath's Avatar
Liked 370 Times in 101 Posts
And that is cheap.
Damn, I wish you would go away !
Jerry Heath
I/S '93 Cobra
FS/J 2010 Mustang "Ebay CJ"
