Liked 17,153 Times in 1,559 Posts
From the NHRA tech department.....
NHRA Technical Department Makes Parity Adjustment to the SAMTech.edu NHRA Factory Stock Showdown Based on SAMTech.edu NHRA Factory Stock Showdown performance numbers from the first race of the 2019 season, the NHRA Technical Department is increasing the supercharger top pulley size on the 2019 COPO 350 combination from 3.350 inches to 3.500 inches and the 2019 Cobra Jet 327 combination from 3.250 inches to 3.500 inches. This will decrease the 2019 COPO 350 combination supercharger overdrive from 147.5 percent to 136.6 percent overdrive or 10.9 percent. Additionally, this will decrease the 2019 Cobra Jet 327 combination supercharger overdrive from 146.2 percent to 128.6 percent or 17.6 percent. As a reminder, no other changes may be made to all approved superchargers, including, but not limited to: (upper or lower pulley sizes, gear ratios, cases, rotors, etc.). All other permitted combinations in the SAMTech.edu NHRA Factory Stock Showdown will remain unchanged. This rule change will go into effect immediately. NHRA reserves the right in the future to make additional rule changes to control performance and maintain parity in the category. |
Liked 2,638 Times in 440 Posts
That didn't take long.
Bill Seabrooks - superfan1 Bridgeport, CT |
Liked 94 Times in 24 Posts
About how much will they slow down?
George Fitzpatrick 426 HEMI STK, SS |
Liked 299 Times in 112 Posts
Take off the weight from the DragPaks!
Liked 370 Times in 101 Posts
They all weigh the same.
Jerry Heath I/S '93 Cobra FS/J 2010 Mustang "Ebay CJ" |
I thought they add 25 to drag pak and removed 25 from copo was that rescinded ?
Liked 226 Times in 137 Posts
NHRA Mudding up the water with no actual testing to see the real world results!
#8 | |
Liked 574 Times in 137 Posts
http://nhraracer.com/content/general...434&zoneid=132 |
#9 | |
Liked 135 Times in 74 Posts
Doing it quickly will keep interest in class. Also, changing pulley size is probably least expensive thing to change. Will they have to do a lot of testing, sure, but what top teams are not doing a lot of testing. Class has basically become Prostock version 2.0 18 wheelers hauling stockers around. |
#10 | |
The big Question becomes who's Sandbaging when and where?
