Old 03-31-2019, 06:21 PM   #1
e vassar
Liked 273 Times in 109 Posts
Default Solid roller lifters for LT1
Time to make the change...any recommendations?
Old 04-01-2019, 06:41 AM   #2
carl hinkson
Liked 18 Times in 10 Posts
Default Re: Solid roller lifters for LT1
Morel lifters as they are to OEM size and will fit an OEM lifter bore
I have found ISKY, COMP, Crower run to small for OEM bores.
carl hinkson is offline   Reply With Quote
Old 04-01-2019, 05:46 PM   #3
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
What advantages do Solid have over Hydraulic?
Old 04-01-2019, 07:31 PM   #4
bob shirley
more RPM for one
bob shirley is offline   Reply With Quote
Old 04-02-2019, 06:45 AM   #5
carl hinkson
More RPM better profiles more HP
Old 04-02-2019, 02:32 PM   #6
e vassar
The first year with this car we used nothing but Lucas 10-30 full syn racing oil. We ran out of it and decided to try Royal Purple 5-30 . We had 2 rockers come loose enough to lay over to the side just idling up to the lanes.one of the adjuster nuts was cracked. I put them back and checked all the others. At Houston the next week after a good pass, a different one came loose in the shut down area,and...the adjuster nut was cracked. So I'm thinking what was the one thing we changed?...so I fixed it again drained out the RP put on new filter.filled it with Mobil 1 10-30 raced the rest of the weekend with no problems. So I'm thinking those lifters aren't staying pumped up unless the car is screaming down the track.
Old 04-02-2019, 02:50 PM   #7
killintime6968
Liked 91 Times in 29 Posts
I don't think solid roller lifters are legal in stock.
Bruce Cameron
68 Nova 396 E/S
68 Camaro SS/? ex Checkmate Modified
killintime6968 is offline   Reply With Quote
Old 04-02-2019, 03:17 PM   #8
Lee Valentine
Liked 319 Times in 68 Posts
Yes they are.
Lee Valentine 1661 STK
Old 04-02-2019, 03:47 PM   #9
Liked 5,150 Times in 1,966 Posts
This is a modern LT1 , I believe. It came with roller lifters.
Old 04-02-2019, 04:40 PM   #10
Jeff Stout
Liked 708 Times in 285 Posts
Yes on late model LT1 having roller lifters. Yes to killentime6968 on converting to solid
