Old 04-18-2019, 11:53 AM   #1
340Cuda
Liked 805 Times in 341 Posts
Default Dana 60 lube
How much gear oil are you all running in your Dana 60s?
I think stock capacity is 2.75 quarts. I have been running two quarts and have been wondering if others have had good luck with less.
I am not talking about one heads up run but for the whole season.
Thanks,
Bill Lamb
Old 04-18-2019, 12:14 PM   #2
Mike Pearson
Mike Pearson's Avatar
Liked 1,948 Times in 589 Posts
Default Re: Dana 60 lube
I run 2 qts of synthetic in my Dana. I have also tried 1 qt with no difference in performance.
Mike Pearson 2485 SS
Old 04-19-2019, 10:46 AM   #3
Patric Fox
Patric Fox's Avatar
Liked 11 Times in 8 Posts
I agree with Mike, 2 qts. of synthetic gear oil. The AMX had a lot of runs on the previous gear set, with Royal Purple gear oil in it. The gears came out looking perfect, and are in the trailer as a spare set.
Patric Fox is offline   Reply With Quote
Old 04-20-2019, 10:07 AM   #4
Tom Goldman
Tom Goldman's Avatar
Liked 883 Times in 237 Posts
I've safely run 1 1/2 qts for years in my Javelin and the Willys with Dana 60's .
I've used 75w/140 synthetics in them with no gear or bearing wear over thousands of runs over the years..
Any brand with similar viscosity ratings and GL5 rating should perform the same.
