Old 04-22-2019, 08:28 AM   #31
Rich Biebel
Rich Biebel's Avatar
Liked 544 Times in 213 Posts
Default Re: oil filters
Originally Posted by CMcAllister View Post
FilterMAG is the brand name of a line of oil filter magnets sold at the mail orders and other places. Magnets are very strong and they work well. Probably a good idea especially if you are using a larger micron rated filter.
No love for the System 1 type filters or the Clear View see through mounts?
I Saw 2 instances of the system one filter blow the o-ring out and both were during dyno testing...…
One was a dirt track engine and one was a Pro Stock 500 cube engine. Made a mess......
Rich Biebel
S/C 1479
Stock 147R
Old 04-22-2019, 01:16 PM   #32
Ed Wright
Ed Wright's Avatar
I used a System1 filter on my dirt track Sprint car back in the ninties. Never an issue with O rings, but did not filter as well as a NAPA (Wix) 1061. I sent my spare filter with my friend at the Sunoco lab when they did the oil filter tests I had mentioned.
Taking them apart for inspection & cleaning was easier & more convient than cutting a filter apart. Did not filter as well.
Ed Wright 4156 SS/JA
Old 04-22-2019, 09:06 PM   #33
Eman
Liked 133 Times in 76 Posts
Originally Posted by Dana Fitzpatrick View Post
The magnets sound like a good idea,I will get some. I see Home Depot sells Rare Earth magnets.Will those work? Thanks for the good info.
https://www.ebay.com/itm/12-NEODYMIU...ss!37660!US!-1
Here's a link to some high heat magnets. Magnets lose their magnetism when heated up and they don't regain it.
Here's a good source and some good info on magnets.
https://www.kjmagnetics.com/
I can tell you if you buy some of these you will be amazed. They aren't toys and it sounds crazy but you can get a blood blister real easy with some of the disc magnets they are so strong. If you stick them together you will have to slide them apart or use pliers to get them apart.
Old 04-24-2019, 07:05 PM   #34
Dana Fitzpatrick
Liked 10 Times in 6 Posts
Bob and Eman,thanks for the information on the magnets.
Dana Fitzpatrick is offline   Reply With Quote
Old 04-25-2019, 03:10 PM   #35
cmracing
Liked 62 Times in 29 Posts
KJ Magnetics has got to have the largest selection of anyone! I have bought magnets from them for the past 16 years. From the tiniest magnets I used with Hall Effects for RPM pickup to magnets that could probably lift a car!
cmracing is offline   Reply With Quote
