Old 04-23-2019, 07:47 PM   #11
Keith 944
Keith 944's Avatar
Default Re: Super Street Help
Weight, shift, or timing, you can also unhook the back two barrels on your carburetor that knocks off usually .5 I’m pretty sure the nessa series runs on a .500 tree you may have to roll in a bit but that helps kill ET also
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
Old 04-23-2019, 07:49 PM   #12
Keith 944
Keith 944's Avatar
While you’re there talk to a lot of the other racers most of them are really good guys and will help you out. If it were me in the summer months I would kill it with weight only that can be very consistent
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
Old 04-23-2019, 09:34 PM   #13
scamper
Thanks all for the tips.That plate deal sounds pretty slick if anyone knows more info on who makes that for the spring/fall.Weight sounds like the ticket for the summer zone et.I know a couple of guys that run in the nessa from the bracket side.Any more tips or tricks keep em coming.
scamper is offline   Reply With Quote
Old 04-23-2019, 10:25 PM   #14
Jeff Stout
Liked 708 Times in 285 Posts
Trying to locate the bracket racer that uses the restrictor plate here in Az. If I find the manufacturer I will post on this thread
Old 04-23-2019, 11:00 PM   #15
Jeff Stout
That didn't take long
ET Genie or EZ Plate.
Old 04-24-2019, 12:21 PM   #16
nickh
nickh's Avatar
Liked 677 Times in 203 Posts
Both of these are excellent choices
Old 04-24-2019, 12:30 PM   #17
scamper
Been reading a bit on the ez plate but some of the forums are saying hes out of bussiness?? I sent an email guess we will see if i get a response.Anybody got goods and bads for these systems,et genie or ez plate:/fuel changing,different starting line stuff squirters etc.
Again Thanks All
Old 04-24-2019, 12:52 PM   #18
Jeff Stout
I googled both. Appears everyone is in business still. ET Genie looks to be better as you adjust slide to open or close opening. EZ Plate you change plates out. No tuning change needed as its below carb according to companies
Old 04-24-2019, 01:37 PM   #19
Lenny5160
Lenny5160's Avatar
Liked 431 Times in 224 Posts
I've heard good things about this one. Just make turns, and it is supposed to be pretty linear. Don't need to keep a stack of plates around; infinitely adjustable within its range.
http://www.willyscarbs.com/adjustable-restrictor-plate/
S/ST 51
S/C 53
Old 04-26-2019, 06:33 AM   #20
scamper
Still no reply from ez plate and the phone just goes to a full message box??? Sent a email to the et genie have yet to hear back.Anyone have better contact info for the ez plate folks than whats on their web site?
