Old 04-28-2019, 05:20 PM   #1
Tony Fagnilli
Liked 205 Times in 44 Posts
Default FS/AA vs FS/XX
I was checking out the entry lists for some of the NHRA national events and saw some guys entered in FS/XX. What's the difference between FS/ XX and FS/AA?
Tony Fagnilli is offline   Reply With Quote
Old 04-28-2019, 05:57 PM   #2
Superfan1
Superfan1's Avatar
Liked 2,638 Times in 440 Posts
Smile Re: FS/AA vs FS/XX
FS/XX is the class designation for the Factory Stock Showdown cars which run in their own separate eliminator. FS/AA is the designation for the cars that choose to run in Stock eliminator. The Factory Stock Showdown cars that don't qualify for the eliminator are not allowed to run in Stock eliminator. A FS/XX car can run in FS/AA by adjusting weight to meet the FS/AA weight break which is 5.50 - 5.99 lbs per factored HP. Conversely a FS/AA car can run in FS/XX by adjusting weight accordingly. The Factory Stock Showdown is contested at 8 National Events this year.
Bill Seabrooks - superfan1
Bridgeport, CT
Old 04-28-2019, 06:16 PM   #3
Tony Fagnilli
Default Re: FS/AA vs FS/XX
Thanks superfan. But, they are entered in stock, why are they not entered in the showdown?
Old 04-28-2019, 06:19 PM   #4
Tony Fagnilli
For example. Cody Phillips is entered in FS/XX at Bristol, in stock. There is no FSS contested at this race. So why is he entered in stock as an XX car?
Old 04-28-2019, 08:33 PM   #5
MR DERBY CITY
Liked 8,106 Times in 1,531 Posts
Probably about 350 grand a season.....
Old 04-29-2019, 09:03 AM   #6
Superfan1
Superfan1's Avatar
When he goes through tech, he will tech in as a FS/AA.
Bridgeport, CT
Old 04-30-2019, 11:17 AM   #7
Bobby DiDomenico
Liked 101 Times in 52 Posts
There was talk on here about different Shootout superchargers and maybe a few other things in a post, are they allowed in Stock eliminator?
Old 04-30-2019, 02:29 PM   #8
bsimms89
bsimms89's Avatar
Liked 72 Times in 20 Posts
The engine combo's currently used in the shootout are "legal" in stock but many of them are rated at a hp that put the car over the maximum allowed weight of 3,600lbs for an SFI25.5 7.5 second cage. for example the 2016-2018 COPO were delivered with a 350 with the whipple rated at 580 hp (currently factored to 617), but the rulebook also allowed a 590hp version(currently factored to 630hp) the difference between the two included superharger puller size, rocker ratio difference, and some valvetrain stuff. In the 2019+ COPO's they come with a 600hp rated 350 with the magnuson, or there is a 630hp verison also in the rulebook, again just different pulleys and rocker ratios.
With the current weight break of 5.5 in FS/AA once a combination is rated over 623hp the car will be over 3600lbs, the specs for the 7.5 second cage is limited to cars under 3,600lbs. Based on the rules you can run the higher rated shootout motors in FS/AA but it would put you over 3,600lbs so you wouldn't be permitted to make a run faster than 8.5 seconds because the cages aren't certified to 7.5 seconds at those weights.
bsimms89 is offline   Reply With Quote
