Liked 20 Times in 16 Posts
Any suggestions where I can get a generator slide out tray that will hold 200 lbs?
Drew Wonderly SST 159 |
I got the brackets at Home Depot and then put a very thick piece of wood across holds my Honda 3000 fine
Liked 24 Times in 17 Posts
Home Depot has some heavy duty slides that are usually in the Hardware Section. Basically just heavy drawer slides. Inside of the display drawer they will have the weight rating for each one.
I think the brand is everbilt Here are the ones I got. Mounted them on a piece of aluminum angle. For the tray use aluminum angle for the perimeter with aluminum treadplate riveted to it for the floor. https://www.homedepot.com/p/Everbilt...ZP-W/302867528 Last edited by NSSGTO; 04-30-2019 at 12:15 PM. |
Yes basically what he said
very heavy duty works fine. I like his idea of how to finish it mine looks factory I covered it in carpet I would take a picture of it but I left the trailer at Atco
Liked 708 Times in 285 Posts
Used the same brackets for a BBQ grill that stowed away in basement of motorhome. Pulled it out and cooked. Held up fine for having a regular size grill on it
Liked 12 Times in 4 Posts
I had a generator slide out made by Fast Farms Trailer Sales in Florida
He will need the dimensions of your generator and how far you want it to slide out. His # 561-968-3757 Good quality workmanship. |
Thanks guys for the advise and ideas.
Liked 13 Times in 9 Posts
Vintage trailers sells one that is excellent,I have it in my Outlaw and two other racers have bought one after seeing mine, sells for around $200.
Liked 62 Times in 29 Posts
I made slide outs for both of my trailers. Bought the slides from McMaster-Carr.
