#11 |
Liked 118 Times in 41 Posts
I think i and going to try air bags on both sides running more pressure on the right side. Cheap fix at under $100,
I noticed in the video that the T-bird did not drop in the rear at all. Doesn't a T-bird use the same set up as a mustang in the rear?
U/SA 79 Mustang |
#12 |
Liked 173 Times in 52 Posts
Same as a T-bird 78 to 88 I believe. My car didn’t squat much until I softened the compression on the shocks.
#13 |
Liked 370 Times in 101 Posts
Has anyone tried these ?
Jerry Heath I/S '93 Cobra FS/J 2010 Mustang "Ebay CJ" |
#14 | |
Always something! |
#15 | |
Liked 358 Times in 83 Posts
Back when dinosaurs roamed the earth, guys who raced coil spring rear suspension cars (I'm thinking about 60s Chevelles) just installed an Air Lift airbag in the right side spring, inflated it to the minimum psi required to kill the roll rotation and all was right with the world. Worked like a charm, was way cheap and didn't have any real effect on anything but the problem. |
#16 |
Liked 184 Times in 113 Posts
In my 1969 Impala Stocker.
Used Airbags and glued a piece of 2by4 on axle housing. On launch it hit the pinion snubber. |
