Liked 1,104 Times in 302 Posts
Quick Time scattershield for SB MoPar. SFI version with window for easy counterweight adjustment. comes with block plate. SFI sticker expired. $400.00
MoPar input shaft for G Force G101A 4 speed transmission. 1 3/16"x18 "Hemi" spline. $250.00 MoPar front bearing retainer for G101A trans. $90.00 Also have a Long shifter mounting plate only for Long Pistol Grip V Gate shifter for G101A 4 speed. standard location (20 1/2" from front of case). $30.00 Homemade shifter mounting plate for Long Pistol Grip V Gate shifter, with shifter rods. (no Heim rod ends, just the tubes). Locates shifter 26" from front of case, This bracket locates the shifter about 2 inches higher than standard position, so reverse lever on trans points up, rather than down. $60.00.
Hello sir, is the mopar main shaft and bearing retainer still available? Thank you, have a great day.
Not a main shaft, but an input shaft, and front bearing retainer. Yes, both pieces are still available.
I apologize for that, I dont know why I said main shaft. Fantastic. I'm trying to get things situated to install a GF4A/101A behind a 440. Are you still looking to get $250 for the input and $90 for the bearing retainer? Also, if you have any advice or experience you can share on this type of trans in a mopar, that would be really awesome. Thank you, have a good day sir.
Liked 242 Times in 81 Posts
Rory you have a PM
Rod Greene Real men shift for them selves. Slowly working on TA Challenger for D,E/S and a 72 Challenger for SS/K, L as if I don't have enough other projects. |
