Liked 17,488 Times in 1,595 Posts
NHRA Technical Department Makes Parity Adjustments to the SAMTech.edu NHRA Factory Stock Showdown
Based on the SAMTech.edu NHRA Factory Stock Showdown performance numbers from the first five races of the 2019 season, the NHRA Technical Department is reducing the minimum weight for all pre-2019 Chevrolet COPO and Ford Cobra Jet combinations from 3,525 lbs. to 3,450 lbs. Additionally, the 2019 Cobra Jet 327 combination upper supercharger pulley size will be increased from 3.750 inches to 4.000 inches and the 2015 Drag Pak 354 combination upper supercharger pulley will be decreased from 3.125 inches to 3.000 inches. As a reminder no other changes may be made to all approved superchargers, including, but not limited to upper or lower pulley sizes, gear ratios, cases, rotors, etc. All other permitted combinations in the SAMTech.edu NHRA Factory Stock Showdown will remain unchanged. These rule changes will go into effect immediately. NHRA reserves the right in the future to make additional rule changes to control performance and maintain parity in the category. The updated SAMTech.edu NHRA Factory Stock Showdown Rules and Procedures document can be found on NHRARacer.com under Rules/NHRA Factory Stock Showdown/Rules and Procedures. |
#2 | |
Bill Seabrooks - superfan1 Bridgeport, CT |
#3 | |
Liked 38 Times in 17 Posts
Sure is more expensive to race a CJ than the other 2 brands.
K Danner STK 468 |
#4 | |
#5 | |
K Danner STK 468 |
#6 | |
Liked 5 Times in 2 Posts
1.158 3.270 5.029 139.26 6.555 7.852 173.21
Adriel Paradise, Paradise Racing Team Driver/Crew Chief(at least my dad claims me to be) B.S. Mechanical Engineering, University of Arkansas |
#7 | |
Yes it was one of the best sixties. Kevin Skinner has some of the best sixties every race, you wanna give him a break too?
K Danner STK 468 |
That some good data regarding the splits. Ultimately, I disagree with your basis for judging parity. Parity can't be determined simply on potential but potential and what the cars are doing on the track. I believe that the data collected so far would dictate a change to helpout the dodges. Obviously I'm biased but i also dont think I'm off base either. I haven't looked at the averages but if they tell a different story, I'll happily admit I'm wrong.
Liked 805 Times in 341 Posts
I certainly don't have the stats to back my opinion up, but it would appear to me that to anyone that was watching these cars the same day at the same track would think that the Cobra Jets were the fastest, then the COPOs then the Drag Packs.
With these three cars being so different, making them "equal" is no easy task. |
Liked 3,020 Times in 722 Posts
I know it is hard to make 3 different cars equal. As long as they keep all 3 competitive with each other is all that I ask. I hope this doesn't become another Pro Stock fiasco.
Ron McDowell - Did Race Every day is a Gift - Enjoy with family and friends. |
