Old 07-07-2019, 11:07 PM   #1
Nmbr1GMfan
Default Grade point question.
Is there somewhere I can go see what it took (grade point wise) to get into specific races last year?
Todd Greene
Old 07-08-2019, 07:12 AM   #2
jmcarter
jmcarter's Avatar
Default Re: Grade point question.
To my knowledge there’s no way to find that out other than racers stating it here based on their own experience But believe the races in Pomona, Vegas, Charlotte, Norwalk, Chicago, Sonoma, Reading, and Gainesville are the ones you typically need 4 or more GP’s for. Others fill early also but withdrawals are common. Others can possibly offer more but I’m sitting at 3 GP and doubt I could get in any of those I’ve named.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 07-08-2019, 07:13 AM   #3
HR9121
HR9121's Avatar
Todd there's nothing like that I'm aware of but if there was one that you're curious about I'm sure someone up here could remember.
James Williamson
W200 J/SA. SS/JA
Old 07-08-2019, 09:00 AM   #4
Nmbr1GMfan
I'm curious about Vegas #2.
Todd Greene
Old 07-08-2019, 09:34 AM   #5
Dave Muller
Dave Muller's Avatar
Liked 223 Times in 73 Posts
Me too!!!
Dave Muller is offline   Reply With Quote
Old 07-08-2019, 09:40 AM   #6
jmcarter
jmcarter's Avatar
Bet you’re going to need a minimum of 5, unless if you’re in the points top ten, in which case you can get in....that’s spelled out in the entry policy.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 07-08-2019, 11:46 AM   #7
MikeMoller
MikeMoller's Avatar
Liked 254 Times in 78 Posts
Todd,
Most of the more popular races seem to take 5 to 7. Less than that you probably need to try and hook up with someone withdrawing. Good Luck.
Mike Moller
NHRA 203 Q-R-T/SA
Old 07-08-2019, 12:23 PM   #8
Lew Silverman
Lew Silverman's Avatar
Liked 129 Times in 59 Posts
I agree with Jim, because the dates "roll-over" the closer you get to final cut-off. Just for the sake of argument, IIRC, if the quota is filled at Grade 5 and three weeks later someone drops out, it would take a Grade 2 (or more) to fill it. So it might be kind of hard to do what you asked for.
Bottom line is to go to as many Divisionals/Opens as you possibly can. That's your best chance.
Lew
Lew Silverman #2070
"The Wagon Master" N/SA
Old 07-08-2019, 01:43 PM   #9
Mike Pearson
Mike Pearson's Avatar
Liked 1,943 Times in 584 Posts
I had 6 grade points last year and could not get in to the Gators this year closed at 7 as soon as it opened. NHRA keeps cutting the quota each year. I am not sure where that will stop. If you want to race the National events you need 8 grade points to be sure that you can play. Or go to the events that don't fill because the facilities or the track treats the sportsman racers like dirt.
Mike Pearson 2485 SS
Old 07-08-2019, 02:10 PM   #10
MR DERBY CITY
Liked 8,018 Times in 1,526 Posts
At least 6....all that pit space ...just goes to waste....
