Old 07-08-2019, 12:42 AM   #21
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
Default Re: Offset grinding crank ?
Originally Posted by GTX JOHN View Post
The .013 Offset only adds a very small amount of displacement!
The impact is a bit more compression from the added stroke.
Draws .013 more air and then compresses .013 a differential of .026
Plus slightly smaller diameter crank diameter, less parasitic drag.
Most engines it is about 1.5 cuin increase.
Old 07-08-2019, 06:40 AM   #22
Liked 11,030 Times in 2,266 Posts
Old 07-08-2019, 06:59 AM   #23
Dwight Southerland
Dwight Southerland's Avatar
Liked 784 Times in 196 Posts
Excuse me!?! Stroke is measured from BDC to TDC so the "differential" is .013", not .026".
Old 07-08-2019, 11:11 AM   #24
340Cuda
Liked 805 Times in 341 Posts
This may be a stupid question but just because you are allowed a little extra stroke does that mean the piston can come out of the that much more than the spec?
Old 07-08-2019, 12:42 PM   #25
pmrphil
Liked 398 Times in 153 Posts
No, no more than spec. You just don't have to deck the block as much.
Phil Molski
PMR Performance
S/C 1623
Old 07-08-2019, 05:00 PM   #26
Dwight Southerland
Yes. And max compression is dictated by spec limits. Adding stroke does not increase compression except for the additional displacement added to the mix.
Old 07-08-2019, 05:13 PM   #27
Liked 5,153 Times in 1,967 Posts
Wink Re: Offset grinding crank ?
Yes. There are comp. calculators all over the 'net. One can run the numbers and see if you think it's worth the extra effort.
To me, the indexing and smaller pin size are at least equal in value.
BTW, thank you to to Dwight for what you do for racers....Appreciated by 98% of them ,and called names by those who are Left.
Old 07-09-2019, 08:40 AM   #28
Gasket thickness (A) and deck (B) can vary, but total of A+B has to same as or greater than NHRA spec. .000 deck and .040 gasket = -005 deck and .035 gasket or +005 deck and.045 gasket. Give yourself a few extra thousandth to the good side so you can be fearless in tear down.
