Old 07-24-2019, 11:43 AM   #1
HawkBrosMav
Liked 302 Times in 73 Posts
Default Anti-Roll bar in Stock
Does this still need to be a bolt in unit? I don't see it specifically addressed in the rulebook like I thought it used to be. Unless they are just considering it a "Traction bar." Just thought previous versions specifically called out Anti Roll.
Maybe I'm crazy
Brad
Old 07-24-2019, 12:03 PM   #2
JHeath
JHeath's Avatar
Liked 370 Times in 101 Posts
Default Re: Anti-Roll bar in Stock
Maybe I'm crazy
Brad
I think there are a lot of them that are welded in.
Jerry Heath
I/S '93 Cobra
FS/J 2010 Mustang "Ebay CJ"
Old 07-24-2019, 12:04 PM   #3
Tom Goldman
Tom Goldman's Avatar
Liked 883 Times in 237 Posts
must be bolt on . may be adjustable .
Old 07-24-2019, 01:38 PM   #4
HawkBrosMav
Tom or anyone else for that matter, could you show me in the rulebook where this is stated? I'm not seeing it unless as mentioned it's clumped in with the "Traction Bar" section.
Brad
Old 07-24-2019, 06:01 PM   #5
Billy Nees
Liked 7,777 Times in 1,742 Posts
Brad
Under Traction Bars, third sentence, "bolt on traction DEVICES permitted".
Billy Nees 1188 STK, SS
Old 07-25-2019, 09:20 AM   #6
Tom Goldman
Billy is correct .
Although some have argued that the anti-roll bar is not a traction device , NHRA correctly sees it as such.
Old 07-25-2019, 09:34 AM   #7
Billy Nees
Just another interesting (and ignored) Rule Book note,under Traction Bars, sentence4, "device must be installed under leaf spring" which would mean that cal-tracs would not be legal as a portion of the "device" is installed above the leaf spring. Go figure.
Old 07-25-2019, 11:48 AM   #8
CMcAllister
Liked 920 Times in 259 Posts
I prefer for it to be bolt in/removable in some fashion since it is a wear item that is subject to occasional cleaning/lube/maintenance. Easier to get the assembly out of the car to work on it.
Old 07-25-2019, 12:59 PM   #9
HawkBrosMav
I'm going to guess this slides by because it mounts in the original hole the leaf spring mounted in so it's not technically mounting "above" even though the Cal-tracs does lower the mounting hole of the spring itself once installed so it is physically above once installed.
