Old 07-28-2019, 02:50 PM   #1
Grey Ghost
Grey Ghost's Avatar
Liked 210 Times in 88 Posts
Default 66 Plymouth V-100
I'm not very familiar with A bodies. Want to put a 273 in an original slant 6 car. Do I need a V8 K member? If so what year(s) will work?
Thanks
Phil Vos
Grey Ghost is offline   Reply With Quote
Old 07-28-2019, 08:16 PM   #2
Paul Wong
Liked 419 Times in 85 Posts
Default Re: 66 Plymouth V-100
You don’t need a different K member they are all the same. The motor mounts and metal engine brackets are different. They can be found fairly easily. Schumacher makes adapters you can buy a kit
Paul Wong is offline   Reply With Quote
Old 07-28-2019, 08:32 PM   #3
Grey Ghost
Grey Ghost's Avatar
Thank you Paul
Phil Vos
Old 07-29-2019, 12:41 AM   #4
Deeznuts
You will need a V8 car drag link. The slant 6 one is straight and the V8 one is made to clear the oil pan.
Deeznuts is offline   Reply With Quote
Old 07-29-2019, 07:11 AM   #5
Grey Ghost
Grey Ghost's Avatar
Very helpfull. Thank you
Phil Vos
Old 07-29-2019, 11:59 AM   #6
Paul Wong
all the parts you need are 64-66. If you are using a stock style oil pan then you need the V-8 drag link as well. If you use any other style pan you have to fabricate a drag link.
Old 07-30-2019, 05:44 PM   #7
Brian Brinegar
I have the motor mounts and centerlink. PM me if you still need them. Thanks Brian
Brian Brinegar is offline   Reply With Quote
