Old 08-01-2019, 09:58 PM   #11
gsa612
gsa612's Avatar
Liked 280 Times in 139 Posts
Default Re: Electric Water Pump damage
Lyn,here's one from Champion rad it screws into the water drain.Summit also sells them. gsa612
Name:	2in Anode.jpg
Old 08-01-2019, 10:34 PM   #12
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
To protect aluminum the anode has to be more active than the aluminum, which would be a magnesium anode.
To protect iron you can use zinc as an anode.
To protect copper and brass, an aluminum anode will work,
Bob Mulry 7516 STK
A & M Motorsports
Old 08-01-2019, 11:20 PM   #13
Dave Sheehan
https://www.summitracing.com/parts/flx-32060/overview/
F/SA W228
Dave Sheehan is offline   Reply With Quote
Old 08-02-2019, 12:14 AM   #14
Bob Mulry
Bob Mulry's Avatar
Originally Posted by Dave Sheehan View Post
That won't work..
He needs magnesium..
Bob Mulry 7516 STK
A & M Motorsports
Old 08-02-2019, 01:52 AM   #15
Dragsinger
Liked 99 Times in 60 Posts
Another thing to consider, in some cases a rubber-mounted radiator with an electric fan attached to the radiator core needs a ground wire from the radiator core to chassis ground.
Larry Woodfin 471W
Old 08-02-2019, 09:15 AM   #16
Mike Pearson
Mike Pearson's Avatar
Liked 1,943 Times in 584 Posts
Looks like the pump has not been sealed well to the engine or cover and water has bee getting between the pump housing and the gasket causing the corrosion issue. I run what ever water I can find from home or the track and drain my system every day at the track and never leave water in the system when the car is stored between races. I usually leave the radiator cap off when the radiator is empty. My water pump is at least 25 years old and still working. Maybe try coating the gasket with some better sealer when the engine is assembled as the corrosion seems to be in the gasket area and not in the are where the Impeller is located
Mike Pearson 2485 SS
Old 08-02-2019, 09:40 AM   #17
Lyn Smith
Liked 994 Times in 200 Posts
Thanks for all the info. My radiator is copper/brass. I will try the radiator ground,and the anode. It is also damaging my aluminum timing cover,and thermostat housing.
Lyn Smith is online now   Reply With Quote
Old 08-02-2019, 09:56 AM   #18
340Cuda
Liked 805 Times in 341 Posts
So with a iron block with aluminum heads and water pump I would want one magnesium anode and one zinc anode?
Thanks,
Bill
Old 08-02-2019, 10:12 AM   #19
John Dinkel
Liked 263 Times in 68 Posts
Jegs has radiator anodes.
John Dinkel 3295 STK
John Dinkel is offline   Reply With Quote
Old 08-03-2019, 12:30 AM   #20
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
The point of an anode is to put something in the water stream that is weaker than the other metals the water passes over. Then the bad stuff in the water erodes it instead of the stronger stuff. Magnesium is a weak metal. Since they decompose they need to be replaced regulary. That reminds me.....
Dale Shearon
68 Mustang 6394
