Old 08-01-2019, 06:35 PM   #31
Chipper Chapman
Chipper Chapman's Avatar
Liked 166 Times in 71 Posts
Default Re: A/SA 2010 Dodge?
The Stock Eliminator section of the rule book still says the rear axle must retain a corporate relationship with the body. So does Strange now have a “corporate relationship” with gm and mopar so that the S9’s used are legal in Stock Cars? If the cars are being run as production cars, they should have to follow the same rules as the rest of us.
Chris Chapman
1969 Chevelle
NHRA F-G/SA 1090
Old 08-01-2019, 08:09 PM   #32
GTS340
Liked 1,361 Times in 416 Posts
Just the Factory Stock cars (the Rocket ships) Drag Pak, Copo and of course the Cobra Jets all can run the Ford 9". is what I was told. Rules are in place for all others. Challengers have to run a Dana or a 8 3/4 as the Camaros get the normal 12 bolt. Its like building a Super Stock to do so if anyone has looked into building one on their own.
Old 08-01-2019, 08:23 PM   #33
Paul, negatory.
Haven't read a rulebook in 20 years but I know this one . 2009 and newer cars can run a 9" in any brand. It's in there somewhere, right, Big Al?
Old 08-01-2019, 11:09 PM   #34
GTS340
Hi Mark,
I gave it my best to get an answer on the 9" for my 2010 Challenger project. My wallet isn't that big to make a mistake. Real tiny in fact. When I asked I got crickets so I figured it must be a ignorant question on my part. Thanks for the help. I sure would like to see it in writing. Specially since I was getting ready to build it here soon.
Paul Haszlauer
Old 08-01-2019, 11:54 PM   #35
GTS340
I'm just too Mopar to put a Ford in it anyway. Dana here we come.
Old 08-02-2019, 07:23 AM   #36
dartman
dartman's Avatar
Liked 68 Times in 41 Posts
Hi Mark,
Paul Haszlauer
Swing axle differential may be replaced with conventional housing; 9-inch housing permitted in 2008 and newer vehicles; stock trailing arms must be retained, may be beefed up and adapted to housing, must retain transverse spring. Must install Panhard bar. Frame may be notched for driveshaft clearance. Distance between OEM backing plates and OEM wheelbase must be maintained. Coil-over shock or four-link adaptations prohibited. See General Regulations 2:11.
1231 FS/D Drag Pak
1231 E/SA 71 Demon
Kelly MacKay
dartman is offline   Reply With Quote
Old 08-02-2019, 10:53 AM   #37
GTS340
https://www.shophemi.com/p-2587-g-fo...r-end-kit.aspx
Old 08-02-2019, 05:50 PM   #38
Dyno
Dyno's Avatar
Liked 695 Times in 206 Posts
Mike at MPR can help on a rear end for a Challenger.
Dyno is online now   Reply With Quote
