Old 08-08-2019, 11:28 PM   #1
rboyle
rboyle's Avatar
Liked 591 Times in 163 Posts
Default 12V racing battery recommendations
I'm sure it's been covered before but looking for a lightweight 12V battery recommendation over my current Optima red top battery that weighs 38 lbs
Old 08-09-2019, 06:37 AM   #2
Glenn Briglio
Glenn Briglio's Avatar
Liked 974 Times in 310 Posts
Default Re: 12V racing battery recommendations
How much do you want to spend?
Old 08-09-2019, 08:48 AM   #3
rboyle
rboyle's Avatar
Keeping it reasonable like $300 or under
It is only a battery after all
Old 08-09-2019, 09:06 AM   #4
Troy Henderson
Troy Henderson's Avatar
Liked 130 Times in 42 Posts
I actually just posted about this topic on my FB page. I replaced my Optima with a Big Crank ETX30L AGM this season. Weight is 24 lbs and is half the price of a Braille B3121.
https://www.batterymart.com/p-Big-Cr...qWOStM0Zl4z-xU
I received an email for 8% off if you enter "8offaug" this month.
Troy Henderson
Henderson Race Shop LLC 816-520-5389
www.hendersonraceshop.com
Troy Henderson is offline   Reply With Quote
Old 08-09-2019, 10:11 AM   #5
Tom Goldman
Tom Goldman's Avatar
Liked 886 Times in 238 Posts
Check out AntiGravity's line of batteries.
I found out about them from some off road friends and they are really rugged and dependable.
And they are extremely light weight.
A couple of my customers have switched to them with great results. https://shop.antigravitybatteries.co...extreme-power/
Old 08-09-2019, 11:37 AM   #6
Dave Gantz
Liked 251 Times in 125 Posts
If it's feasible, I'd suggest being able to swap back (quickly) from whatever you get to your tow vehicle battery. The battery gods and Murphy get together and take their life usually a few rounds in. :-)
Old 08-09-2019, 12:41 PM   #7
Dragsinger
Liked 99 Times in 60 Posts
This is a subject on which I have experience and thoughts. With my super stocker and my bracket builds, 16 volts has been my choice for a few years.
However, I am softening with that stance and now think a conventional, lead-acid, or AGM 12 volt deep cycle is an overall excellent choice.
In my opinion, the latest, high tech batteries are not yet completely developed to be 100% dependable in the later rounds that come close together when charging time has been little to none..
The Camaro I am building today will have a 27 series, lead-acid, deep cycle battery. It will cost about $110.00, run the car all day, but carries the penalty of weighing 50 pounds. It is trunk mounted and in this situation, the weight is an advantage.
Larry Woodfin 471W
Old 08-09-2019, 01:02 PM   #8
SSDiv6
Lifeline Batteries. Their race batteries are made in the USA and built to MIL-SPEC since the company also builds aircraft commercial and military batteries.
https://lifelinebatteries.com/produc...ing-batteries/
Old 08-09-2019, 10:06 PM   #9
mat H/SA
mat H/SA's Avatar
Liked 14 Times in 8 Posts
Been running odessey for the last 8 years never had any problem and they are not expensive
mat H/SA is offline   Reply With Quote
Old 08-10-2019, 06:51 AM   #10
Liked 10,850 Times in 2,254 Posts
I have used two 11.5 lbs Braille battery's for years in the six pack car with zero let downs. Once the starter acted a little slow, battery was ok just a loose cable. My alternator works. I have tested and could go three rounds without charging in between rounds. I did cool car with sprayer until temp was reached then turn off fan. I change them out every three years.
