Old 08-12-2019, 11:34 AM   #1
e vassar
Liked 272 Times in 108 Posts
Default Alternator question
For a stocker (LS Camaro) running BS3 elec fan,water pump,fuel pump, lights at night. Typical race car...what would be the smallest amp alternator I should run?...thks
Old 08-12-2019, 11:47 AM   #2
Hacksaw
Liked 312 Times in 175 Posts
Default Re: Alternator question
Be careful here. A alternator needs to spin about 2500 rpm or more before it starts to break even and produce + current.
Old 08-12-2019, 10:07 PM   #3
cmracing
Liked 62 Times in 29 Posts
100 amps minimum.
cmracing is offline   Reply With Quote
Old 08-13-2019, 04:00 PM   #4
bigfoot584
Engine rpm's ? or actual alternater rpm's ?
Big difference.
bigfoot584 is offline   Reply With Quote
Old 08-13-2019, 05:33 PM   #5
Hacksaw
Big difference.
Just checked with an old guy who was a rebuilder and had a test bench. From memory he says about 1800 alt. rpm before they began to produce + current. So on a normal pkg. the ratio of crank to alt. pulley is approx. 3 to 1, which means at idle your not producing current back into the battery. Now with a smaller race crank and larger race alt. pulley to avoid spinning the alt. to the moon it's probably 1100 or 1200 rpm. Also they eat up at least 3 hp, maybe more.
