#11 |
Liked 5 Times in 2 Posts
I used to run the optima batteries because they would last forever but they weigh a ton! Recently switched to the Odyssey batteries and have been really happy so far.
5705 F/S 5706 D/SA |
#12 | |
Liked 601 Times in 165 Posts
#13 |
Liked 976 Times in 311 Posts
Which one did you go with?
#14 |
https://shop.antigravitybatteries.co...me-power/v-10/
Hi Glen. The xtreme power 10 cell. |
#15 | |
Liked 70 Times in 31 Posts
Darrel Goheen 785-623-7021 Stock Eliminator 585 94 Camaro Z/28 LT1/ET 585 67 Chevelle 427 Tehnician for JustAnswer.com |
#16 |
Liked 887 Times in 239 Posts
I think you will be happy with it .
Just be sure to follow the charging instructions. Like any battery ,proper charging rate and voltages are key to longevity.
#17 | |
Liked 293 Times in 65 Posts
#18 |
Liked 84 Times in 42 Posts
A few years ago my car wouldn't start for the semi finals at a race and I decided that this was not going to happen again.
Now between rounds I run the fan and water pump from the (2) deep cycle batteries in the trailer normally for the winch and jack. I run 4 ga cables to a switch box and then 4 way cable to a 4 pole plug. The 4 way socket in the car is wired in parallel to the normal wires.
Bob Tilton 568 FS/H |
#19 |
Liked 62 Times in 29 Posts
Made 13 passes Saturday with a single Group 31 in the trunk, 105amp GM alternator supplying the juice, never had my charger out. Doubt there are many cars using as much power as mine:
Dual stock GM F-Body fans, over 20 amps each. Mezier electric water pump. Weldon EFI fuel pump. 8 injectors, though they take very little. 4 coil packs (DIS waste fire setup, like a GN). The last two hours ran the electric fan on the 2nd trans cooler, not sure what it draws. The last 6 passes were made 15 minutes between each, only got to the trailer for fuel. So....... Why mess with these little batteries you have to worry about charging when there are massive batteries out there that will never give you an issue? |
#20 |
Liked 2,513 Times in 701 Posts
I run one or two Walmart budget batteries (either 26 or 56 as I recall)
that weigh 26 Lbs. I have been for 25 years. Easy to exchange on the road if needed. They have recently gone up to $49.95. I do charge them in the latter rounds.
