Old 08-26-2019, 12:30 PM   #1
pfordamx
Liked 7 Times in 5 Posts
Default 28x10.5 slick recommendation
looking at going away from bracket radials to a biasply i'm eyeballing hoosier stiffwalls in co7 compound 18155C07 car is a amx weights 3150 makes about 700hp with new combo and having a hard time hooking the radial consistently transbrake car with about a 6400rpm flash stall. usually leave around 3k off the brake. caltrac bars and calvert leafs and double adjustables the whole way around. might open a can of worms here but would like opinions on the hoosier mentioned and will take other recommendations.
pfordamx is offline   Reply With Quote
Old 08-26-2019, 01:21 PM   #2
Jeff Stout
Liked 708 Times in 285 Posts
Default Re: 28x10.5 slick recommendation
Cant help with Hoosier but I use the 3055S Mickey's when running the small tire or no prep events. Im very similar to your car but alittle less on HP around 595 RWHP. 11 inch rim and 13 lb on prepped and 9.5 lb on no prep
