#11 | |
Liked 272 Times in 108 Posts
Thanks for the good info. |
#12 |
Liked 693 Times in 205 Posts
Rehr-Morrison has a great article in their tech area why you should shut down the engine at the finish line. A valve body with a clean safe neutral should be used however. There are many tech articles on their site but that are a “must read” if you are a racer.
#13 |
Liked 10 Times in 6 Posts
On my stick BBC I push the clutch pedal in and let it idle.Should I also key it off?
#14 |
Liked 8,120 Times in 1,533 Posts
Let me clarify my answer, I am only talking about SBC Stockers with 3 speed GM automatic transmissions with Cheetah shifters...no clean neutral....
#15 |
Liked 372 Times in 130 Posts
I have a TCI shifter hooked to a reverse valve body c-6.
It also will not make a clean shot from 3rd to neutral |
#16 |
Just curious...
Auto trans Go thru the traps at 120 plus Straight to neutral and Shut the engine off and coast I have always wondered how the output shaft gets lubrication since the front pump is not running ?
Alan Mackin Stock 3777/ SS 3377 P/SA & SS/PA Fox Thunderbird I/PS '95 Mustang GT |
#17 |
Liked 173 Times in 52 Posts
#18 |
Liked 140 Times in 51 Posts
I watched the videos here on class racer. Many of the older cars do this and the newer cars seem to leave it in gear. As mentioned some 3 speed trans builders don't recommend it. The clean neutral valve body would be a must, I would think.
The more people I meet the more I like my dog Kevin |
#19 |
Liked 140 Times in 43 Posts
Don't try it without a clean neutral transmission. Period.
#20 |
Liked 229 Times in 99 Posts
Isn't there a danger of the front drum letting go if you free wheel it at that kind of RPM?
Floyd Staggs 787 SST |
