Old 09-04-2019, 08:49 AM   #21
troublemaker427
troublemaker427's Avatar
Liked 64 Times in 23 Posts
Default Re: Shutting off engine crossing finish line
Does anyone sell a clean neutral valve body for a C4 transmission?
Jody Aberts
Troublemaker2
1966 Fairlane 427
Old 09-04-2019, 08:56 AM   #22
Ralph A Powell
Liked 227 Times in 138 Posts
Just push in the clutch that's a clean neutral
Ralph A Powell is online now   Reply With Quote
Old 09-04-2019, 09:04 AM   #23
Dave Noll
Dave Noll's Avatar
Liked 240 Times in 112 Posts
The oldschoolers cut it clean at the stripe to check the spark plugs for jetting, detonation etc.
Dave Noll, EF/S ,?/SA 6526
Old 09-04-2019, 09:32 AM   #24
Floyd Staggs
Floyd Staggs's Avatar
Liked 229 Times in 99 Posts
Originally Posted by Floyd Staggs View Post
Isn't there a danger of the front drum letting go if you free wheel it at that kind of RPM?
Nobody want to venture a comment on this?
I've seen what a T400 drum can do.
Floyd Staggs 787 SST
Old 09-04-2019, 10:22 AM   #25
btrc
Liked 84 Times in 42 Posts
Joel's on Joy.
Bob Tilton
568 FS/H
btrc is offline   Reply With Quote
Old 09-04-2019, 10:24 AM   #26
George Wright
George Wright's Avatar
Liked 408 Times in 35 Posts
Joel's on Joy builds a C4 with a "clean neutral". It is activated by applying 12 volts to an internal solenoid. I have his C4 in both my FGT/G Mustang and my Open Comp T-Bird.
Have a look at the video in this thread: https://classracer.com/classforum/sh...ad.php?t=72903
You will notice I hit a switch on the dash after I go through the top end.
Joel's on Joy phone number: 248-446-6024
George Wright https://9500rpm.com
George Wright is offline   Reply With Quote
Old 09-04-2019, 10:33 AM   #27
GTS340
Liked 1,361 Times in 416 Posts
I've been putting it into neutral and shutting it off after the lights for near 50 years with all my Mopar cars . I never have used a clean neutral valve body. I personally like neutral in between reverse and first.
Old 09-04-2019, 10:41 AM   #28
curtis reed
Liked 126 Times in 60 Posts
Please be kind. LOL I'm somewhat uneducated on class racing even though I really like it. Can you guys run an oil accumulator in stock and or super stock?
If so why wouldn't you then? You can run 3 quarts in the pan and have 2 in the accumulator for slowing down. It seems many have to add weight anyway. Just curious.
Curtis
curtis reed is offline   Reply With Quote
Old 09-04-2019, 01:19 PM   #29
kansas stocker
Liked 250 Times in 49 Posts
I'm thinking after reading all of the above posts that "clean neutral" doesn't mean the same to everyone.
Pete
kansas stocker is offline   Reply With Quote
Old 09-04-2019, 02:10 PM   #30
Hacksaw
Liked 314 Times in 177 Posts
Yes, you are 100% correct, dangerous. I had one fly apart, blew through the case like a bomb went off.
Hacksaw is online now   Reply With Quote
