Old 09-04-2019, 03:52 PM   #1
vic guilmino
Liked 56 Times in 21 Posts
Default rich carb
holley carb go fat at start and low gear in high gear is is about 12.7
need help
Vic Guilmino 1129 STK
Old 09-04-2019, 04:19 PM   #2
Hacksaw
Liked 312 Times in 175 Posts
Default Re: rich carb
Using a power valve in primary side?
Old 09-04-2019, 07:51 PM   #3
Ralph A Powell
Liked 226 Times in 137 Posts
Dripping Bosters?
Old 09-06-2019, 07:41 PM   #4
vic guilmino
yes power valve no dripping
Old 09-06-2019, 08:36 PM   #5
RJ Sledge
Liked 292 Times in 92 Posts
Vic
I’d be looking real hard at the idle circuit.
If your going off a 2-step, wot, it will be rich.
Footbraking you might play around with squirter size, most Holleys are around a 28 Stock I have run as high as a 43.
How fat is it down low ?
RJ
RJ Sledge is offline   Reply With Quote
Old 09-07-2019, 09:38 AM   #6
vic guilmino
10.6 afr
Old 09-07-2019, 07:22 PM   #7
RJ Sledge
If your O2 is in your collector, and it is within 12” from the end, you will not get a “clear” read, it will always show rich until you bring up rpms as in making a pass down the track then it will read correctly.
You can slip on an 18” extension to the end of collector and tune it for lower rpms (2 step leave or foot brake leave). Then take off extension. It’s is sucking air back up past the O2 sensor and it will show rich until you get rpms up and going down track.
Good luck
RJ
Old 09-07-2019, 09:14 PM   #8
Darrel Goheen
Darrel Goheen's Avatar
Liked 70 Times in 31 Posts
Good luck
RJ
Actually it'll show lean.
Darrel Goheen 785-623-7021
Stock Eliminator 585 94 Camaro Z/28 LT1/ET 585 67 Chevelle 427
Tehnician for JustAnswer.com
Darrel Goheen is offline   Reply With Quote
Old 09-08-2019, 08:37 AM   #9
Glenn Briglio
Glenn Briglio's Avatar
Liked 974 Times in 310 Posts
Put O2 sensor in primary pipe.
Old 09-08-2019, 08:51 AM   #10
RJ Sledge
In my experience on a carb combo it showed rich when staging with 2 step at 3000 rpms or so. Moving O2 or extending collector will correct that.
On an efi combo putting an extension on allowed us to tune it so it did not search and go lean/rich while in 2 step staging. Like the computer couldn’t make up its mind up from due to O2 not getting clean data. That was with a BS3 system but believe it to be the same with all.
Believe Vic’s combo is 780 Holley but maybe not.
RJ
