Old 09-04-2019, 04:17 PM   #31
Floyd Staggs
Floyd Staggs's Avatar
Liked 229 Times in 99 Posts
Default Re: Shutting off engine crossing finish line
Originally Posted by Hacksaw View Post
Yes, you are 100% correct, dangerous. I had one fly apart, blew through the case like a bomb went off.
A friend of mine had one let go. Went right by the flex plate shield, through the dash and took out the windshield.
Floyd Staggs 787 SST
Old 09-04-2019, 04:44 PM   #32
Frank Castros
Originally Posted by GTS340 View Post
I've been putting it into neutral and shutting it off after the lights for near 50 years with all my Mopar cars . I never have used a clean neutral valve body. I personally like neutral in between reverse and first.
Have other MoPar racers been doing this?
I was always told not to by very reliable sources although I had always wanted to to kill the motor after crossing the finish line for all the right reasons and at the time it would have been easy because we were still using the push button shifter in the Max Wedge car.
Old 09-04-2019, 05:00 PM   #33
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
Shutting down the engine at speed with an automatic means that there is no pressurized internal transmission lubrication...
The last time I shut off an engine in the lights we were running D/G at Half Moon Bay in 1968...
Just sayin'
Bob Mulry 7516 STK
A & M Motorsports
Old 09-04-2019, 09:49 PM   #34
Adger Smith
Liked 880 Times in 311 Posts
My Slayed Valve odd fire V-6 will shred Jesel belts if you kill it at the finish line. If I put it in clean neutral and let it idle, high idle, the belts last a long time. Guess how I found this out??
Adger Smith (Former SS)
Old 09-07-2019, 07:24 PM   #35
SS3257
I’ve always shut mine off at the finish line. Super stock modified motor turning 10,200.
Jeremy Mudd
SS3257 is offline   Reply With Quote
Old 09-08-2019, 01:09 AM   #36
GTX JOHN
I always put it in neutral and shut off my small block Stockers
at finish if they are turning close to or over 7,500. The Stockers
that are still in the high 6000s....I do not worry about it.
John Irving
741 Stock
741 Super Stock
Old 09-08-2019, 06:54 PM   #37
Frank Castros
With no transmission repucussionions I would imagine . I wish
I would have know this.
Old 09-08-2019, 07:51 PM   #38
John Dinkel
Liked 265 Times in 69 Posts
Thumbs up Re: Shutting off engine crossing finish line
Never had a problem putting trans in neutral after the finish line.
John Dinkel 3295 STK
John Dinkel is offline   Reply With Quote
Old 09-08-2019, 10:51 PM   #39
GTX JOHN
Correct!
All my Protrans stuff always looks great when Dave goes
thru it!
John Irving
741 Stock
741 Super Stock
Old 09-11-2019, 07:13 AM   #40
Liked 10,969 Times in 2,261 Posts
Using a clean neutral helps keep the big end of the rods round longer.
