Old 09-08-2019, 06:51 PM   #11
Adger Smith
Liked 880 Times in 311 Posts
Default Re: rich carb
2 step = rich reading
Adger Smith (Former SS)
Old 09-09-2019, 08:06 AM   #12
Hacksaw
Liked 309 Times in 173 Posts
If it was me I would take out the power valve, plug it and go up 4 jet sizes in the primary. Then evaluate.
Old 09-11-2019, 07:36 PM   #13
Ed Wright
Ed Wright's Avatar
Cams like we run often causes low enough manifold vacuum to open the power valve at idle. The number on the power valve tells you at what point in manifold vacuum dropping as load goes up, it opens. If it says 85, the power valve opens, and adds fuel at 8.5” of manifold vacuum. A “45” will stay closed, and leaner, above 4.5” of manifold vacuum.
When I had my old IHRA Super Mod Camaro, it had the standard 750 cfm Holley we had to run in NHRA. Was a tad faster than an 850 on that 292”. Before I figured out the “High Speed Air Bleeds”, it was going lean at high RPM. I put a vacuum gauge on it to see if it was pulling vacuum “up there”, it was pulling 3” of vacuum in the lights. I went to a “25” Power Valve, and picked up a MPH. Bigger high speed air bleeds was a tad quicker.
Ed Wright 4156 SS/JA
