Old 09-17-2019, 06:45 AM   #151
Adam Strang
Liked 96 Times in 23 Posts
Default Re: Attention Nova 350/255 stock combo.
Looks like a 301 Pontiac head.....
Adam Strang 1018 STK
Adam Strang is offline   Reply With Quote
Old 09-17-2019, 08:18 AM   #152
Rich Biebel
Rich Biebel's Avatar
Liked 555 Times in 216 Posts
A closed chamber BB Chev and the chamber walls have been hit with either a stone or a cutting tool to unshroud the valves.....both intake and exhaust.
In ancient times we used to use an oversized top cut stone with a flatter angle and cut only the intake chamber wall back some with a smooth radius. Could not get away with that on the exhaust side.
Then Bead blast the area and then do what was the accepted and legal VJ of 3 angles and no more than 1/4" larger than valve O.D. top cut.
Many BB heads had a smooth area around the intake and it blended into the chamber wall so you could get away with copying that and making it bigger.....unshrouding the valve....
We did heads and blocks for T/K and they went on record holding cars well know in Div. 1
I did numerous sets of LS-6 heads.....from new castings....before the era of welding.....We did epoxy intake runners on SS heads but nothing more than that....
Rich Biebel
S/C 1479
Stock 147R
Old 09-17-2019, 08:26 AM   #153
Billy Nees
Liked 7,862 Times in 1,750 Posts
What's a 301 Pontiac? Is that the head casting #?
Billy Nees 1188 STK, SS
Old 09-17-2019, 09:03 AM   #154
HP HUNTER
Liked 373 Times in 129 Posts
How do you get a 60 degree angle that wide (.110) on any production BBC head with a factory installed 2.190 intake valve? Anyone..............
Old 09-17-2019, 09:26 AM   #155
oldskool
oldskool's Avatar
Liked 747 Times in 362 Posts
Originally Posted by billy nees View Post
what's a 301 pontiac? Is that the head casting #?
lol !
Old 09-17-2019, 10:01 AM   #156
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
Guess you can weld Cast Iron !
Old 09-17-2019, 10:10 AM   #157
Adam Strang
Don't play games Billy you know that's the pic of the superseded head for a 301. Cya at the Dutch.
Old 09-17-2019, 11:54 AM   #158
GEORGE PETERSON
Liked 11 Times in 6 Posts
Most combos that can run 1.20 under and are factored at less than 1 HP per cubic inch are under factored.
GEORGE PETERSON is offline   Reply With Quote
Old 09-17-2019, 10:08 PM   #159
B Parker
Liked 2,343 Times in 465 Posts
So George what combo do you run? If you use your logic the 350/255 hp motor rated at 280 hp should be rated at 350 hp. That would add about 700 to 800 pounds to most of those that run it. Almost every combo is capable of running 120 under. If you want to spend money and time. Barry
Old 09-18-2019, 07:40 AM   #160
Liked 10,896 Times in 2,255 Posts
Will any of the AA/S or AA/SA run in the 9.40's?
