Old 09-21-2019, 09:47 PM   #1
jamie2370
Liked 239 Times in 90 Posts
Default Hone grit
Having a convo with another person as they were asking about dingleberry hone grit. He said someone told him to use an 800 grit ball hone. Seemed to fine to me. I would normally use a 400 on our bracket motors. What's yalls opinion on the 800? Assume moly or latest tech total seal rings
jamie2370 is offline   Reply With Quote
Old 09-22-2019, 05:46 AM   #2
richie 2
Liked 205 Times in 93 Posts
Default Re: Hone grit
good question. I sometimes wonder if the 400 grt. even seals a std. moly ring street motor? who sells the 800?
Old 09-22-2019, 09:08 AM   #3
Liked 1,883 Times in 423 Posts
You'd panic then when the tech guys at Total Seal suggested finishing with 1000 grit levigated aluminum, counterclockwise for five strokes.
Old 09-22-2019, 10:26 AM   #4
BLKCAM
BLKCAM's Avatar
Ok, I'll bite Alan, counter clockwise? what application was this on?
Life is a series of details.
BLKCAM is offline   Reply With Quote
Old 09-22-2019, 11:15 AM   #5
Hacksaw
Liked 312 Times in 175 Posts
Port side boat
Old 09-22-2019, 11:41 AM   #6
jamie2370
Alan, if that's what they recommend then I would do 1000. I have been taught if it's too slick the rings wont seal. 400 works great on a bracket motor with no risk of a ring not sealing. I've never used anything finer but I know on a stocker motor that a ring combo can make or break you. That's why I asked.
Old 09-22-2019, 03:52 PM   #7
SSDiv6
Like Alan said, call Total Seal and speak to Keith.
Piston ring material and technology has changed drastically.
We are no longer in the era of breaking-in Chrome rings.
Old 09-23-2019, 08:46 PM   #8
richie 2
can someone reasure me please (because ive never deglazed, usually hone .0005" out of the block)....sbc bracket motor, 400 grit deglazing balls provides suffenent finish for sealed/power plasma ring set?
Old 09-23-2019, 09:35 PM   #9
jamie2370
Yes Richie, that's all we use on our bracket motors with the "best" standard ring combo stuff. These stocker motors are using super thin ring sets that will not last very long at all if the finish is too rough. I'm still learning the new technology stuff.
Old 09-24-2019, 03:17 PM   #10
Rob Wright
Liked 21 Times in 7 Posts
If you're working with a harder block, you will want to use a silicon carbide abrasive. By numbers, a 400-grit Flex Hone will deliver rpk of 8-12, RK of 18-22, and rvk of 28-32 on harder blocks / sleeves.
This is what I've seen with my Mitutoyo SJ-210 profilometer after doing 20-ish strokes in clockwise direction, and 5-ish strokes counter-clockwise, with 400 grit silicon carbide hone, on Darton sleeves. In other words, excellent results.
Mileage may vary.
Rob Wright is offline   Reply With Quote
