Old 09-24-2019, 11:32 AM   #1
joespanova
Liked 13 Times in 11 Posts
Default Thunderbolt weight
If I read correctly , an A car in S.S. carries 6lbs / hp. So the factory "rated" the 427 ( was that a tunnel port?) at 425 hp? So Paquet's car only carries 2550 / 2600 lbs?
http://www.classracerinfo.com/NHRA_Classes.aspx
or:
http://classracer.com/classes.html
so is it LBS / hp or LBS / cid?
Old 09-24-2019, 11:56 AM   #2
troublemaker427
troublemaker427's Avatar
Liked 64 Times in 23 Posts
Default Re: Thunderbolt weight
Hi Riser, not a Tunnel Port
Jody Aberts
Troublemaker2
1966 Fairlane 427
Old 09-24-2019, 12:08 PM   #3
joespanova
OK , and..........
I wanted the weight confirmation....? Am I close ?
Old 09-24-2019, 12:25 PM   #4
Nick Heath
Liked 566 Times in 135 Posts
Super Stock factor for the T-Bolt is 466 (or 482 with replacement heads).
466x6.00 + 170 = 2966# or 3062# with replacement heads.
Nick Heath is online now   Reply With Quote
Old 09-24-2019, 12:45 PM   #5
joespanova
So at some point they added the 170......
Thanks
Old 09-24-2019, 01:05 PM   #6
JeremyDuncan
Liked 355 Times in 80 Posts
Wink Re: Thunderbolt weight
170 lbs is added for drivers weight
JeremyDuncan is offline   Reply With Quote
Old 09-24-2019, 01:19 PM   #7
joespanova
Ahh , ok..so the cars weight is / are independent of the driver. We need skinny drivers then...LOL.
Old 09-24-2019, 01:35 PM   #8
kansas stocker
Liked 249 Times in 48 Posts
They are weighed together so the weight can come out of the car as is necessary in my case.
Pete
kansas stocker is offline   Reply With Quote
Old 09-24-2019, 01:40 PM   #9
joespanova
Pete
Thats what I would have guessed.....the total weight is combined. Like Pro Stock .....2350 w dr.
I don't know why he indicated the 170?
I'm confused...........again....lol.
Old 09-24-2019, 02:02 PM   #10
kansas stocker
The car weight is figured as rated hp X lbs/hp for class plus 170 for the driver. All drivers are figured at 170 and you make up the difference from there.
Pete
