Liked 53 Times in 38 Posts
Can one of these trans used in a stocker be used on the street? Hemi 18 spline trans are $2000 and up. That much into a trans might as well step up to a better one.
Mike |
Liked 62 Times in 23 Posts
Can be used on the street, just exercise "double clutch'' technique on up/downshifting to extend trans. life. Full throttle shifts, same as on track. Tony
Liked 165 Times in 59 Posts
you can do it,if you have truck driving experience with a 10 speed that will help the learning curve ,, oh lots of gear noise !
Liked 200 Times in 62 Posts
I wouldn;t do that, never had any luck shifting it slow !
Liked 327 Times in 87 Posts
Liked 1,988 Times in 600 Posts
You won’t have any problem shifting that transmission on the street. It is face tooth design and you won’t need to use the clutch. Just ease off the throttle and move the shifter smoothly and quick. The straight cut gears will be noisy and down shifting should not be done. It will wear pretty fast.
Mike Pearson 2485 SS |
Liked 137 Times in 46 Posts
With practice you will get a feel and can and will shift like butter....
John A. McLaughlin 5757 B/S 440-6 or G/S 383 70 Road Runner, Dad's 5096 K/SA 70 Two Ton Tamater, Taylor's,Alec,Breezy |
#9 | |
Liked 23 Times in 13 Posts
Agree ! It is all technique and practice. That said it is a non-synchro box so there will be times in traffic where you just have to slam a gear and go. People will look at you like something just fell out the bottom but it's part of the tradeoff for a strong powershifting box. |
Liked 6 Times in 2 Posts
I'd be looking for a Jerico WC (Winston Cup) version that has the road race sliders. Never tried one but they are designed to down shift. DR-4's don't like downshifting although on occasion I can get mine into a lower gear without drama. The gear noise will likely make you crazy and yes, they sound like parts are falling out.
Dale Posnick |
