Old 09-25-2019, 02:59 PM   #11
bsimms89
bsimms89's Avatar
Liked 72 Times in 20 Posts
Default Re: Thunderbolt weight
NHRA assumes all drivers weigh 170 lbs, so going over the scales the car and driver have to weigh : rated horsepower X class weight break +170 lbs. So if a driver weights 200 lbs the car cab be 30 lbs lighter, if the driver weighs 150 the car has to weigh 20 lbs heavier.
Just making up numbers say you have an engine rated at 350 hp and in a class with a weight break of 8.0, the car and driver going over the scales has to weigh: 350 X 8.0 + 170 = 2,970lbs. It doesn't matter what the car or driver weight independent this is the weight they have to be at on the scales, no matter what engine or class you're in you need to add the 170 lbs to the hp and weight break calculation.
bsimms89 is offline   Reply With Quote
Old 09-27-2019, 08:21 AM   #12
Rusty Gillis
Rusty Gillis's Avatar
Liked 87 Times in 19 Posts
Also saves time at the scales. When I raced SS back in the 70's they just went by car weight. The driver had to get in and out of the car now there is a sticker on the window with the minimum weight with driver and he doesn't have to get out.
Rusty Gillis
Former NHRA SS/FA and SS/GA record holder
Rusty Gillis is offline   Reply With Quote
