Old 10-04-2019, 09:43 PM   #21
00SSCamaroZ
Liked 11 Times in 4 Posts
Default Re: Engine diapers on S/SS?
Well I don't think I've ever seen a stocker oil the track. However at the Dutch on Friday afternoon a blue 69 camaro did a moonshot wheelstand and upon landing pitched out what appeared to be the trans blanket. That was something new in my world.
Mike Z
00SSCamaroZ is offline   Reply With Quote
Old 10-04-2019, 10:33 PM   #22
Dinsdale
Dinsdale's Avatar
Liked 6 Times in 2 Posts
We had a Jr. Dragster oil the track this year. Last weekend it was a Stick car that split the trans case. Numerous rear end explosions, auto trans blowups, oil line leaks and rad hose failures. I'd think engine failures are becoming a lot less with improved and accepted parts.
I'm all for safety but how many Diapers should be on a race car anyway. If you want to run one then fine, but I don't, probably can't fit one and don't think making them mandatory is a good move.
Dale Posnick
Dinsdale is offline   Reply With Quote
Old 10-05-2019, 07:15 PM   #23
Doug Walker
Doug Walker's Avatar
Liked 3,182 Times in 298 Posts
Mike Z
Are you referring to this ?? Blue Camaro was in the left lane. Debris was in the right lane, but may have originated from either car.
Does not look like 1969 Camaro to me, but maybe more than one car pitched its safety gear off mid track.
First time I'd ever seen this happen.
ID:	52460   Click image for larger version
Old 10-06-2019, 06:02 AM   #24
Mike Jones
Liked 684 Times in 289 Posts
Originally Posted by Bill Grubbs View Post
Depends?
He said Depends
Old 10-06-2019, 08:17 AM   #25
00SSCamaroZ
That looks like it. Thought it was a 69. Obviously not. Guess I am not a good eye witness.
Mike Z
Old 10-06-2019, 09:38 AM   #26
rboyle
rboyle's Avatar
Liked 588 Times in 163 Posts
We had a D1 race where 3 Stockers oiled the track during the first Qualifying shot. I myself have oiled it twice. First when I bought the car I was the first car down the track at No Problem and spit a rod out at bat mid track broke the trans driveshaft and pinion yoke too. Shut the track down for almost 2 hours. So yes it does happen.
Old 10-07-2019, 07:07 AM   #27
Liked 10,837 Times in 2,252 Posts
After looking at the B-E body engine, steering, and headers on my stocker, it would be a lot of work and expense. The drag link runs real close to the sump and the bottom of pan, this could be a potential crash if the Kevlar blanket jams the steering. A motor plate would not help the steering situation. A tray might work until a big wheel stand. When that happens on my car it bends the oil pan against the pickup, and bends the transmission pan. The oil pan I have to fix before I make the next run. If new ss headers are needed to complete the ORD I will be done.
All of a sudden cutting bait doesn't look so bad.
Old 10-07-2019, 09:37 AM   #28
Pat6868
Liked 88 Times in 28 Posts
Stock eliminator- entry level. Mandatory belts every 2 years, mandatory approved collector tethers, now mandatory diapers? Sad to see the so-called evolution of this class.
Pat6868 is offline   Reply With Quote
Old 10-07-2019, 10:14 AM   #29
Dyno
Dyno's Avatar
Liked 693 Times in 205 Posts
On a Hemi car with the drag link going through the oil pan (some Chevy ll’s also), I do not know how you could fit a diaper effectively. If NHRA allowed an aftermarket K frame, it might be possible.
Old 10-07-2019, 10:35 AM   #30
Steve Stasko
Liked 274 Times in 143 Posts
I must have done something wrong on my '64 Dodge when I put the engine diaper on it. I have the factory K-frame, steering, and torsion bars. Using 1 3/4" Hooker S/C headers (one tube through fenderwell). I fit a universal Jeg's diaper on the car without issue, though I did have to get creative with some of the mounting points for the support straps to hold it up.
I wasn't real fond of putting it on, but when the rules require it (I ran the car in S/ST a few times...ex-SS car), you find a way to make it work if you want to race.
While the Jeg's diaper doesn't provide the best fit, I can only imagine how much better the job would have been had I used something that was designed for the car.
